backseat water leak
Old 10-28-2009, 12:27 AM
trevor151's Avatar
backseat water leak
It's been raining a lot here the past two weeks and I noticed basically a puddle of water in my backseat driver's side floorboard. I checked under the car and tried following the dampness trail but couldn't find the culprit. i have a sunroof, but if it was leaking wouldn't my headliner be damp too? I hadn't gone through any high waters or anything either. Any one know what the problem is or what I need to check? Thanks
Old 10-28-2009, 10:01 AM
Coblasts's Avatar
Drain tube is leaking for the sunroof at the rear and the water is coming down the side between the back window and the door.
I think the water has to pool on the headliner to make it soak through and otherwise it just runs right off of it .
Old 10-28-2009, 10:04 AM
BlueStang's Avatar
If your still under warrenty take it to the dealer
Old 10-28-2009, 04:17 PM
trevor151's Avatar
okay thanks, i'll check the tube out
biniecki
10-25-2015 02:23 PM
brandon04
10-21-2015 07:04 AM
tomj77
10-04-2015 11:39 AM
nathan112i
09-30-2015 07:12 PM
Slick_Nick
09-28-2015 09:15 PM
Quick Reply: backseat water leak
