Bad ball joint, or?
Bad ball joint, or?
07 SS S/C.
If I grab the tire at 3 and 9, there's a ton of play.
If I take the wheel off, the ball joint moves but everything else seems good.
Everywhere I read says tie rods at 3 and 9, but mine look good. Zero play in them.
So I guess my question is, what else would allow a ball joint to move around like this when wiggling at 3 and 9, other than a bad ball joint itself?
I had a shop replace them years ago, so they were bolted in.
You probably could do the factory ones with the control arm still attached. You'd just have to make sure you could get a drill and air chisel in there.
