bad brakes cause light?
Old Apr 14, 2010 | 05:07 PM
murph909's Avatar
TC and ABS Lights on UPDATED
So my abs and traction control lights are on (I know that when one comes on so does the other), my brakes are bad and need replacing.. is it possible for bad brakes to cause the lights to come on? they most often come on after stopping or while stopped, and will sometimes be on sometimes be off when starting the car. I will get it looked at but I am jsut curious if this is possible
Old Apr 14, 2010 | 05:08 PM
PRND3L's Avatar
no, its more likely you have a bad wheel speed sensor if its occuring during those conditions.
Old Apr 14, 2010 | 10:28 PM
murph909's Avatar
thanks, and awesome quote lmao
Old May 4, 2010 | 12:14 AM
murph909's Avatar
K so my lights turned off about three weeks ago and havent come on since, but I have made no changes or done anything with the car other than driving it around... does this make any sense?
Old May 4, 2010 | 05:21 PM
scottie's Avatar
Not completely sure how this site works, just joined. But if it came on and off, and has been off for three weeks could have very well been a wiring issue. Or some dirt/grime in your abs sen. Just a possibility.
Old May 4, 2010 | 06:01 PM
roderick's Avatar
My abs light was one and I replaced the sensor in my car and then I see a wire cut it was the wire harness for the abs sensor. Check your wires then replace sensor.
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
