BadMab Header Gasket Leak...HELP!
So, I need some Help here...I'm super Frustrated with the Gaskets that BadMab give you with the Header
, I Installed my Header like 2 months ago and I started getting a fairly Loud ticking sound when ever I would start the vehicle. Come to find out that the Brand new gaskets that BadMab give you w/ Their new Header Suck Ass and I had to replace them with OEM Gaskets. So, I Replaced the Gasket where the DP goes into the flange of the Header and guess what? A week or two later its Leaking again! WTF! I asked my Tech at my work if the Flange was Warped and he said that he didnt think so, But I'm thinkin that it might be(He's a Ford Tech) cause what the Hell else could it be???? Thanks
i been having the same issues, my flange was bent ever so slightly and thats really all it takes. i got shafted like this
but then i talked to brad mabry and he helped me out... i wound up getting a new one for ef are double ee
Nice Animation Lol....So did you put the New one on yet? Any Leaks with the new one?
The only thing I had to take my car to a mechanic for was the same problem you're having but I have the zzp midlength combo. They filed down the flange and used some different gasket, not sure what kind though.
i'm still using it>> https://www.cobaltss.net/forums/prob...t-leak-245329/
here is the one i used. i made one and still have the other half of the sheet. works great!! COLLECTOR/CONNECTOR Flange Exhaust Gasket
I'm having the same problem. I installed my bad-mab last week and it's leaking. I really like the header but I'm hoping I can get it to seal.
Sep 28, 2015 12:51 PM
z28addiction
Sep 28, 2015 12:03 AM
