Battery problems?
Old Sep 17, 2010 | 06:33 PM
Render2009's Avatar
Battery problems?
Since I got my car I've had battery trouble it always dies if my car sits for 2 days. I already replaced it last winter and I'm having issues again..anyone else have these issues?
Old Sep 17, 2010 | 06:35 PM
Black SS/SC 06's Avatar
I have had an optima red top since I bought the car. Never had a problem. Even when I was stationed in Wyoming.
Old Sep 17, 2010 | 06:37 PM
Render2009's Avatar
Alright I'll have to try something else out
Old Sep 17, 2010 | 06:44 PM
Have you had the alternator tested?
Old Sep 17, 2010 | 06:56 PM
Render2009's Avatar
no i havent? where could i get that done
Old Sep 17, 2010 | 06:57 PM
I think they do it at auto parts stores. Not sure, haven't had to get mine checked in a while. Any mechanic should be able to do it though.
Old Sep 17, 2010 | 06:59 PM
Render2009's Avatar
alright ill look into it hopefully that will tell me somthing my cars only got 20k miles if that matters
Old Sep 17, 2010 | 07:02 PM
I wouldn't think you would have problems with that low of miles. Maybe your battery doesn't have enough Cold Cranking Amps?
Old Sep 17, 2010 | 07:09 PM
Render2009's Avatar
maybe im not sure. i leave my radar detector plugged in to.. maybe thats it my parents think that could be it but i dont see it doing that but idk.
Old Sep 17, 2010 | 07:10 PM
Tomtwtwtw's Avatar
You also have an aftermarket audio system...if it wasn't wired right, it could be draining your battery while the car is off. It's worth looking in to.
Old Sep 17, 2010 | 07:14 PM
Render2009's Avatar
its not draining it my amp light would come on if it was still getting power.
Old Sep 17, 2010 | 07:15 PM
There is no point in leaving it plugged in though. It's going to draw power from the battery. Could be part of the problem. I don't think they draw that much power though.
This too. It could me numerous things, you just have to see if anything you change solves the problem. For instance, unplugging your radar detector when your car is just going to sit there for two days
Old Sep 18, 2010 | 01:05 AM
scottie's Avatar
Maybe you bought a cheap ass battery? Or just got a shitty one.
Have that and your alternator checked. Although its not going to be your alternator if it only dies from sitting. A drain would be your most likely answer.
Old Sep 21, 2010 | 03:26 PM
Gearblock's Avatar
Had this exact same problem two years ago buddy. Only happened in the winter tho. Then it magically went away... i realized my trunk light burnt out tho, maybe that sucker was drawing energy or some ****.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
