Bent Radiator Support
Old Oct 1, 2011 | 07:51 PM
Mike08ss/tc's Avatar
When my motor blew in my car I had to tow it with a truck. The kid that towed me bent the **** out of my Radiator support. It is bent 4in to the left from the gm performance badge under the hood.
This is not a serviceable part. Someone on here has had to run into this problem before. How did you fix it. Not so nice to look at now.
Old Oct 1, 2011 | 08:09 PM
MastaShaKe_88's Avatar
damn, are they gonna cover it??
Old Oct 1, 2011 | 08:46 PM
No. Can't even get a part for it. Part of the frame or chassis
Old Oct 1, 2011 | 08:47 PM
guitarenvy's Avatar
you towed from under the hood?
I got pulled out of sand in my mustang 10ish years ago, lower rad support bent. I couldnt straighten it. On the cobalt, it is a welded on peice that can be replaced for a large bill. I can look it up if you really need. It is a body shop repair.
Old Oct 1, 2011 | 08:49 PM
StruttinSoul's Avatar
My rad support bent in my accident, the gm collision place was able to fix it up.
Old Oct 1, 2011 | 09:36 PM
Malaclypse's Avatar
You can replace the upper core support but you have to drill out the spot welds and re-weld it. I think you also have to check the alignment of the frame when you do this.
Fun stuff.
Old Oct 1, 2011 | 09:38 PM
BLAZIN07SS's Avatar
I'm too JDM for you
COBALT G5 RADIATOR SUPPORT TIE BAR UPPER PRIMERED STEEL | eBay
the good part is that the part is cheap, getting it installed? probably not
Old Oct 3, 2011 | 09:12 AM
Since my car is lowered there was no way without him ripping my bumper and my intercooler off. I work at Gm and it is not a servicable part. Im going to call gm today and see what part tech has to say.
DarrenGC
Dec 24, 2021 01:55 PM
Spanky's Monkey
Mar 7, 2016 06:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
