Bit of an odd issue
Old Apr 11, 2014 | 10:18 PM
dwarrick's Avatar
Bit of an odd issue
I dont know if anyone has run into this, but I figured if anyone has heard of the problem they would be here.
Doing a few pulls with the car, everything working as should. Then one of the the pulls the car starts making a fluttering noise. Kind of sounds like a wastegate type flutter noise ( car is TVS but same sort of noise) and also down on power a bit.
Only thing I can think that would cause that is the bypass valve.
Only makes the noise when car is under moderate to heavy load.
Anyone run into anything like this before?
Old Apr 11, 2014 | 10:22 PM
Powell Race Parts's Avatar
whats the boost gauge do?
do u run meth?
vacuum leaks?
plastic fender liners secure? lol
Old Apr 11, 2014 | 10:29 PM
Weird, in for results
Old Apr 11, 2014 | 10:57 PM
dwarrick's Avatar
do u run meth?
vacuum leaks?
Hey John,
Boost seems lower than before. It doesn't seem to fluctuate with the noise, but it is electronic and not vacuum operated so it might not pick up the fluctuation fast enough
Negative to the meth. Have not done a vacuum leak check yet. Car seems to run fine at idle, but hard to tell sometimes with cams. Liners and bumpers all look secure
I will smoke test the lines as they are original and were starting to look weathered.
Is there any good way of testing the bypass valve or boost solenoid other than replace and hope for the best. I guess I could try and strap the valve closed and see if the problem stays or goes
Old Apr 12, 2014 | 08:39 AM
Originally Posted by dwarrick
Hey John,
The valve is default closed with spring pressure.takes vacuum to open. it can seize open esp long term with meth use which u have not been using. i would say vacuum leak get some decent 4 mm silicone hose off ebay or whereever...my .02c
Old Apr 12, 2014 | 09:19 AM
dwarrick's Avatar
I will try that and post back with results. Thank you sir
Old Apr 15, 2014 | 06:04 PM
Chevrolet Cust Svc's Avatar
Hi dwarrick,
I’m sorry to hear that you experience noises within your vehicle. I am not properly trained to offer technical advice, but I will like to look further into your concern. Please send us a private message if any extra assistance is needed. Thank you.
Kristen A.
Chevrolet Customer Care
dennis69
Oct 20, 2015 04:49 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
