Blow By
Blow By
When I pull off my oil cap while the car is running, I get alot of gases coming out. Its feels the same as my exhaust, it's quite warm, "puts" like the exhaust, and smells like exhaust.
Also, I find that my oil turns black pretty quickly.
Could this be a problem with my engine? Or is that much blow-by normal?
For each cylinder, crank engine through 4 compression strokes.......The lowest reading cylinder should not be less than 70 percent of the highest.....No cylinder reading should be less than 100 psi.
I was just wondering what a "normal" reading for a 2.2 is, like 180psi is what is normal for my honda
then you should see that I said none should be LESS then 100 psi.....GM doesn't give an exact number....as long as all 4 cylinders are in close readings I doubt you have anything to worry about...but I personally would be happy with about 150 psi
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
breds2k
19
Sep 21, 2015 10:24 AM
