Blown motor guys...
Old Aug 27, 2007 | 03:33 PM
SSdan's Avatar
Blown motor guys...
Guys with the blown motors, when it popped, did the car keep running? If not, when restarted did it idle?
I was just going down the road, 2nd at about 4500-5250RPMs and it shut off, RPM went to 0. No power reduced, no check engine light. Nothing. Pulled over tried restarting, won't idle. Cranks over fine, won't idle at all, not even with the gas.
My first thought was blown motor. Second thoughts now are crankshaft or camshafts sensors. I read a while back if they go the car won't idle. Maybe i'm wrong or something.
Car seems fine now. I still want to do a compression test one of these days. Who knows. Freak PCM accident?
Old Aug 27, 2007 | 03:50 PM
Jackalope's Avatar
Any coolant in the oil? What have you checked so far?
Old Aug 27, 2007 | 05:25 PM
beamSS's Avatar
mine wont idle right and stalls. never had CEL right after i blew it. take it for a compression test ASAP.
Old Aug 27, 2007 | 05:31 PM
SSdan's Avatar
Its fine now. I went back a half hour later and it started right up, like it never happened.
I think the PCM had a freak accident.
Some more information to gather thoughts. I haven't had a misfire in forever. I don't take the car over 6000 RPM (2.8" on stage 2 tune and injectors), and if I do it is for barely a 1/2 second. No check engine lights besides the 1st week I had the car(Crankshaft Position Sensor Malfunction) and even then the car ran beautiful and started perfectly.
Anyone think the PCM just had an accident?
Old Aug 27, 2007 | 05:41 PM
Jackalope's Avatar
I'd say take it in and get it checked out just to be safe. Glad your not dead in the water.
Old Aug 27, 2007 | 05:46 PM
SSdan's Avatar
Yea if it happens again it's going in asap. For now, I think i'll just do a compression test.
There was no coolant in oil and vice versa.
I also thought the JB weld inside the SC silencer holes popped and got sucked in. Thank god it didnt happen. I think i'll be taking the blower off and dremeling the **** out. I don't need it ruining my motor.
Old Aug 27, 2007 | 05:51 PM
Jackalope's Avatar
Ok, What? Where did you put JB weld that it could be sucked into the engine? And why?
Old Aug 27, 2007 | 06:07 PM
SSdan's Avatar
Underside of the blower, 2 bleeder holes. Fill them in and the SC is much louder. Cobra and Lightning drivers do it for many a miles with no problems.
Old Aug 27, 2007 | 07:41 PM
Area47's Avatar
Rent me! per hour
Old Aug 27, 2007 | 08:32 PM
firemanfrank's Avatar
CRANKSHAFT SENSOR
CRANKSHAFT SENSOR
CRANKSHAFT SENSOR
Exact same thing happened to me with just 1500 miles on the car, and peeps on this forum told me what it was.
Trip to the dealer confirmed it.
Sensor was replaced under warranty (but it took a few days for them to get the part).
Old Aug 27, 2007 | 08:36 PM
KillerBee's Avatar
cat over temp probably cat got to hot
Cobalt2.4ss/sc's Avatar
quick question why so many problems wit the 2.0 ss/sc?..why does it always just turn off by itself
Old Aug 27, 2007 | 08:37 PM
KillerBee's Avatar
casue it sometimes gets to hot and automatically shuts off
Old Aug 27, 2007 | 08:50 PM
BlilBT's Avatar
Protection Mode!
Old Aug 27, 2007 | 09:07 PM
Because it wants to! And what the Supercharger wants, the Supercharger gets.
LOL
Seriously though, there aren't "so many problems" with the SS/SC.
Simply get the crankshaft sensor replaced, and we're doing just fine!
Old Aug 27, 2007 | 09:10 PM
kool hope it wont turn off on me when my s/c is on there lol
Old Aug 27, 2007 | 09:43 PM
Fast Freddy's Avatar
Originally Posted by firemanfrank
CRANKSHAFT SENSOR
CRANKSHAFT SENSOR
CRANKSHAFT SENSOR
Agreed!!
Old Aug 27, 2007 | 09:58 PM
SSdan's Avatar
I thought the crank sensor as well. I had a code at 260 miles for the sensor. They reflashed and it never came back. It is running perfectly well again and until it happens again it won't go in to the dealer.
The car was only about 160* degrees. WOT in 1st, tiny clutch slip into 2nd followed by a chirp and then bang, off it went.
Old Aug 28, 2007 | 08:21 AM
A crankshaft sensor CAN NOT be fixed by a "reflash". It must be replaced.
Seems like all the dealer did was just remove the Check Engine light.
The Service Dept. at my dealership would not even let me drive my car home until the part came in, because they said it could go again at any time.
You might want to try another dealer ...
Old Aug 28, 2007 | 09:19 AM
SSdan's Avatar
I definately will. Next time my car goes in for service of ANY kind, this is being brought up.
Old Aug 28, 2007 | 09:25 AM
chevysalesman614's Avatar
i had a freak incident once. it died out on me, then wouldn't crank over. i pushed it to the side of the road, and tried again. started right up.. and i had no problems after that. only thing i could come up with is that maybe one of the pcm connections was not fully connected.
Old Aug 28, 2007 | 09:28 AM
Mine wouldn't turn over for almost 10 minutes. I was ready to call for a tow truck when I decided to try it one more time, and then it started up/ran fine.
Crankshaft Sensor replaced .....
Old Aug 28, 2007 | 09:41 AM
SSdan's Avatar
Mine didn't turn over for 10 minutes and when it would try, the car would shake terribly. Called Onstar and they sent out a truck. 30 minutes later I tried one last time and it fired up perfectly.
Solaris99
28
Mar 15, 2017 01:22 PM
ThoR294
Oct 4, 2015 08:44 PM
Stuff
Oct 1, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
SlowSaturn
Sep 28, 2015 11:03 AM
