Boost gauge bouncing
Old Nov 21, 2012 | 07:08 PM
serega12's Avatar
Car is fully warmed up. I was parked at work and noticed it bouncing (happens very rarely). When I rev it up, it goes back to normal...
What could be the problem? The rest of the gauges work fine.
https://www.youtube.com/watch?v=lUSXzpi50iU
Old Nov 22, 2012 | 01:14 PM
Nfamous60's Avatar
could be a slight boost leak maybe , mine use to bounce a lil but i have a digital AEM so its extra sensitive
Old Nov 22, 2012 | 01:32 PM
Team SS's Avatar
TTR Powered
Put you a Manual Boost Gauge in lol. Mine did that before, but find out it was the gauge..
Old Nov 22, 2012 | 11:30 PM
serega12's Avatar
manual boost gauge? I thought ours is a manual, not a digital...
Old Nov 22, 2012 | 11:32 PM
user 72239's Avatar
ours is digital. it may look manual but it gets boost readings from the MAP sensors and not actual vacuum.
Old Nov 22, 2012 | 11:35 PM
SylverSS/SC's Avatar
the stock gauges are electronic not digital. They get their signal from the ECM which reads the manifold pressure from the MAP.
Mechanical boost gauge is more accurate
Old Nov 23, 2012 | 05:39 AM
serega12's Avatar
Would it be a direct swap, plug-n-play? Sounds like I'd have to run a pressure / vacuum lone or do dome rewiring or soldering...
I'm still under extended warranty from GM with $100 deductible. How much is a manual boost gauge? Just trying to see if it's worth it or just wait until it completely goes and then take it to the dealer.
Old Nov 23, 2012 | 07:27 AM
BlackARCA06's Avatar
My stock boost gauge went bad, Said i was boostin 30 when I was at 22 so I bought the AEM one and its all good now.
Old Nov 23, 2012 | 01:19 PM
prevsrt4owner's Avatar
Well, considering you'll never see positive pressure while just idling and revving, I'd say the gauge is messed up.
Does it return to zero with the engine off?!
Old Nov 23, 2012 | 04:30 PM
serega12's Avatar
Yes. It works completely fine most of the time. When I shut if off and take out the key, it stays at whatever the gauge is at when I shut it down (usually 19-20 inHg).
If I put the key in to the ACC (or whatever is the one before cranking it) it jumps back to 0... It acts totally fine... this only happened twice or so (that I noticed) so I'm not worried about it. at least not yet.
Old Nov 23, 2012 | 04:40 PM
Boost gauges run about 150 for a mechanical one. You would have to run a switched power wire to the gauge and a vacuum line to the intake manifold. It's worth it
Old Nov 23, 2012 | 05:39 PM
serega12's Avatar
Ok, thanks man. I'll look into that when mine completely fails.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
