Boost Issues @ CEL after radiator/OEM DP Install
Old Oct 10, 2012 | 02:44 AM
lrk322's Avatar
Hey everyone,
My issue-
I have an 09 SS/TC with GMS1 and my car is throwing CEL P2227 for the Barometric Pressure Sensor. It will boost to around 5 ps -10 psi and then stop and the boost will drop.
__________________________________________________ __
What happened-
Was removing zzp dp to put on my stock (selling it soon enough). Car slipped & smashed my radiator.
I dropped the fan putting the new radiator in (works fine), is it possible the plug that goes into the fan is having an issue?
Thoughts-
Wondering if I messed something up putting in the radiator of reinstall of oem downpipe?
Prior to this I had no issues besides the code from my DP. (Assuming my flash was fine. Didn't have ZZP DP on until a month after GMS1 and no issues then)
At the time of the install I did unplug the battery to clear the DP code, same time as radiator @ DP- not sure if that has anything to do with this either.
Since then I have unplugged the battery for 30 min and checked the connections on the intake manifold so far...
Thank you for any help or ideas!
-Lane
Photo by lanekrarup • Instagram
Old Oct 10, 2012 | 10:51 AM
lrk322's Avatar
Hey guys, any ideas why an OEM DP and radiator install would cause boost issues and a cel?
Old Oct 10, 2012 | 10:59 AM
Chevycobaltss3's Avatar
Check your map sensor in lower charge pipe...
DarrenGC
Dec 24, 2021 01:55 PM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
