Boost problem
Old May 25, 2015 | 11:14 PM
vman156's Avatar
Boost problem
I have a 2006 cobalt ss sc and I'm having a boost issue. I replaced fuel filter and plugs . I'm only pushing 9-10 lbs wot. The car feels sluggish wot until I reach around 4k rpm. Can you guys help figure it out . Thank
Old May 26, 2015 | 12:33 AM
cobaltss#01's Avatar
any codes and what mileage?
Old May 26, 2015 | 09:34 PM
vman156's Avatar
Nope no codes and 120000 miles thanks for the replay
Old May 26, 2015 | 10:00 PM
you replaced the plugs and fuel filter after you realized the boost was a little lower than normal or it started happening after you did plugs and filter?
Old May 26, 2015 | 10:38 PM
vman156's Avatar
Before , thats why I thougth it needed to be replaced. Any ideas ?
Old May 26, 2015 | 10:39 PM
Not trying to sound like a dick, but you used the correct heat range plug and gapped them correctly?
Old May 26, 2015 | 10:49 PM
vman156's Avatar
It's all good man but yes and I gapped them at .35
Old May 26, 2015 | 10:57 PM
Make sure you don't have a plugged air filter or a leak at the IM gasket or the blower to IM
Old May 26, 2015 | 11:05 PM
vman156's Avatar
Good stuff Thanks , I just replaced cai .is there any sort of leak test I can perform
Old May 27, 2015 | 05:11 AM
this^^^. Make sure the air filter is in the correct way also.
Old May 27, 2015 | 06:41 AM
What CAI did you install?
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
