Boost problem
Old Aug 5, 2015 | 11:44 PM
budah93's Avatar
Boost problem
I have an 06 S/C stage 2 and I'm having an issue building boost. All the threads I've read have slightly different issues than mine so I'm making a thread to get it fixed. When I floor it in first gear my boost builds up to around 5 psi then drops until I hit 2nd gear and from 2nd gear on I can't build boost past 5 psi. Any suggestions? Also I'm pretty dumb when it comes to fixing cars so pardon me if I ask a "stupid question"
Old Aug 6, 2015 | 12:35 AM
Bluelightning's Avatar
Got Bewst?
Check your boost bypass that's attached to your supercharger. Notorious for failing and causing your symptoms.
If you want more info as to things you can do to bypass it to see if it's the problem just do some searching. You'll find what you need.
Old Aug 6, 2015 | 11:17 AM
budah93's Avatar
Tried that and still can't build boost over 5. Any other suggestions???
Old Aug 6, 2015 | 11:21 AM
budah93's Avatar
I'm idling right around 15 hg but when I floor it gets to 5 and stops. I can hear the supercharger whine
Old Aug 6, 2015 | 11:44 AM
Got Bewst?
Perhaps then the gauge is broken if you can hear it whine. You probably wouldn't with only 5 psi.
Old Aug 19, 2015 | 06:06 PM
budah93's Avatar
took my car to a shop didn't have any leaks at all and my aeroforce gauge is saying my boost is the same as the stock gauge, Anything else that might be causing the issue?
Old Sep 2, 2015 | 02:55 PM
budah93's Avatar
my car all of a sudden last night decided it wanted to build a little more boost. I can now hit around 10 psi but it doesn't get up there until i'm at almost redline. sits just under 5 until about 5500rpm then will get up to 10ish, is this normal for our cars?
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
