boost problem?
Old Jan 25, 2007 | 10:11 PM
rocky101104's Avatar
boost problem?
hey you guys, need a little help. is it noraml for me not to get more then 5 or 6 psi's in first gear. i noticed that a couple of days ago. everything other gear is fine. thanks for any input.
Old Jan 25, 2007 | 10:13 PM
Stilgar's Avatar
Honestly I never look at my boost guage in first, I always look at the tach. Let others chime in.
Old Jan 25, 2007 | 10:14 PM
c0ld29's Avatar
yeah i noticed i get almost no boost in first also, i think its supposed to be that way
NightriderCobaltSS's Avatar
As far as i know yea it is. If every other gear is fine then you dont have a boost leak.
Old Jan 25, 2007 | 10:18 PM
another quick question, i have an 05 ss/sc and my headlights fog up. my last car was an '02 and those headlights looked amazing compared to the ones i have now. is this under warranty or anything, or is there a way to fix this?
Old Jan 25, 2007 | 10:20 PM
Stilgar's Avatar
Bring that **** in, GM has to replace that under warranty. Thats like the body panels not lining up good.
Are they the stock headlights ? how many miles do u have on it ?
Old Jan 26, 2007 | 08:57 AM
SKDR112888's Avatar
you should still get the same amount of boost in every gear, I do
I get alomost 13 on the stock pulley
Old Jan 26, 2007 | 08:59 AM
kenhebe's Avatar
Perfectly normal. I have an 06 ss/sc with the GM stage 2 kit and a GM stage 3 pulley. I don't get very much boost in first, but all others are normal.
Old Jan 26, 2007 | 09:01 AM
SKDR112888's Avatar
I get the same amount of boost in all gears,
you should as long as your at full throttle, of course you just spin out but you should still get the same amount of boost
Old Jan 26, 2007 | 09:14 AM
cobaltstg2's Avatar
before i got tune i was seeing normal levels of boost but now i only see 5 at most cause i had boost turn down with hpt
Old Jan 26, 2007 | 10:04 AM
my car is completely stock. i only have 15100 miles on it. are the headlights covered under warranty. should i take the car to the dealer about the boost to make sure?
Old Jan 26, 2007 | 10:09 AM
blown06's Avatar
I never noticed when I was stock but after my tune i really dont get any boost in first to help with traction then 2-5 its on lol
Old Jan 27, 2007 | 02:49 PM
rukkee's Avatar
I remember seeing 10psi in first gear stock with my 06.
Old Jan 27, 2007 | 08:36 PM
wickednick911's Avatar
i only see 10 in first and 12/13 in the rest.
dealer gave me this sheet it has a little info.
http://i50.photobucket.com/albums/f3...ck911/pic3.jpg
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
