boost problem, please help
Old Apr 10, 2010 | 03:17 PM
zay52790's Avatar
I recently got a ported and polished s/c and i had a 2.8" pully on it. It hit 17psi on the 2.8
More recently i swapped the 2.8 for a 2.6, but now I'm only hitting around 16psi. I have checked for boost leaks, and i couldn't find anything, but i plan to check again just to be sure. I cannot figure out what the problem could be, so if anyone could point me in the right direction it would really help.
As far as cooling goes i currently have it set up with a zzp s3 heat exchanger and the zzp single pass intake manifold
Old Apr 10, 2010 | 03:19 PM
BLAZIN07SS's Avatar
I'm too JDM for you
check for any leaks post blower. particularly the SC gasket. and if not do the boost bypass mod to make sure it is not bleeding off boost
Old Apr 10, 2010 | 08:24 PM
reddevil's Avatar
put the 2.8 back..
Old Apr 11, 2010 | 01:35 AM
zay52790's Avatar
what is the boost bypass mod?
Old Apr 12, 2010 | 12:41 AM
07Slobalt_1's Avatar
if you upgraded your exhaust recently, that could make your boost appear lower.
Old Apr 12, 2010 | 03:15 PM
zay52790's Avatar
yea but even with the new exhaust and stuff it should still be boosting more than 16-17 psi on a 2.6
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
