Boost Question.
Old Mar 20, 2014 | 05:50 PM
dtec's Avatar
Boost Question.
Ok guys, I bought an 06 cobalt ss/sc a while ago. I was told it was stock, I didnt know much about these cars so I didnt find out till later that the car had a 2.8 zzp pulley, which was the only upgrade...problem was the car was still running on stock injectors and no tune, scared that it might lean out on me I didnt beat on the car anymore. I bought a stock pulley and belt, I had the pulley changed back to stock. Now my problem right now is, before I changed the pulley i was able to hit close to 13 pounds of boost, now that the stock pulley is on I can only hit about 6-7 pounds, is this normal or should i still be able to hit around 10-12 lbs? Thanks.
Old Mar 20, 2014 | 06:28 PM
SunburstSS's Avatar
Your car probably has exhaust work done to it along other stuff, take pictures of your exhaust setup from header to muffler along engine bay shots and some pictures of those injectors as well so we can better assist you.
Old Mar 20, 2014 | 06:54 PM
dtec's Avatar
E4 Photo by dtec921 | Photobucket here are pics...I'm pretty sure everythingss stock
Old Mar 20, 2014 | 06:56 PM
dtec's Avatar
And those pics are before I changed the pulley back to stock but nothing has been done to it since
Old Mar 20, 2014 | 06:57 PM
06cobaltncng's Avatar
didnt beat on it but with it only having a 2.8 and no other mods you went to 13#s of boost?
Old Mar 20, 2014 | 07:39 PM
dtec's Avatar
When the 2.8 was on I was able to push 12-13#s close to redline but stopped doing that because I found out that it was very dangerous considering I'm running a 2.8 without tunenor injectors, so I drove normally for a couple of months, and today I finally changed it to stock and I push like 7-8 pounds max close to redline.
Old Mar 20, 2014 | 07:43 PM
BlackielawlessSS's Avatar
That's pretty normal. I think I saw 10 one time when I was stock. I get to 15th on a cold non humid night with a 2.8, 60s, and a hp tune.
Old Mar 20, 2014 | 07:45 PM
dtec's Avatar
Yea as long as that's normal, I'm going to get zzp 3" intake sooon. And I want to delete the resonator, any suggestions?
Old Mar 20, 2014 | 07:50 PM
mrbelvedere's Avatar
I have a suggestion use the search button and post in the correct section
Old Mar 20, 2014 | 07:52 PM
I am on my phone but I'll answer it in later if it hasn't been answered by then.
Old Mar 20, 2014 | 07:53 PM
Should be 11.5 psi stock
You might have a clogged cat or bad boost bypass deal
Old Mar 20, 2014 | 10:51 PM
soaxin's Avatar
I hir 17 psi max on stage II no other mods. Eveything is working fine.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Bohb
Sep 27, 2015 09:11 PM
