boosting problem
Old Jul 9, 2009 | 01:13 AM
hymer741's Avatar
Exclamation boosting problem
Hey guys
Well it all started Monday night, i was doing some friendly runs between me and the guys, and i noticed that my car wasn't pulling near as hard as it should be. i checked my boost gauge during one of the pulls and it never read over 10psi (normal is around 16-18) and my supercharger wasn't making a normal whine. It kinda sounded as if a kid was yelling through a giant fan.. you know what a mean? lol. So i pulled ever immediately and my first thought was to check the bbv.. but i couldn't see any signs of being abnormal..
So after that i go straight home to see if I can see what's going on. On the way I do a quick pull.. and it pulls hard, like normal. So at this point i was like wtf. I oiled my bbv, thinking that was the problem and went to sleep.
Car seems fine Tuesday although i didn't drive it much. Then tonight i decide to test it again. I did a 2nd gear pull at 40 and it boosted straight to 15psi and crawls up. I shift to 3rd and boost falls to 12psi and fluctuates from there, and even falling down to 10psi (under WOT) never really getting back to 15psi.. It was also making that weird, non-normal whine.
I'm pretty stumped lol.. i've checked all my vacume lines and lubed my bbv. I was also wondering if it was a slipping belt.
I have a 60's and 2.75 setup with damn-near full bolt ons. i've had this setup for a month now and this is my first problem..
So please CSS.Net!! help me out lol
Old Jul 9, 2009 | 01:15 AM
JimzSS's Avatar
bost by pass valve or boost by pass solinoid
Old Jul 9, 2009 | 01:30 AM
hymer741's Avatar
going bad or what??
please elaborate
Old Jul 9, 2009 | 09:48 AM
rnjmur's Avatar
Could be the belt slipping, could be the boost bypass as well.
Have you checked to make sure you aren't getting knock and checked to see what your IAT2 is at?
Old Jul 9, 2009 | 10:30 AM
hymer741's Avatar
haven't checked knock but my iat2's were at like 110-120 with an ambiant temp of 85.
Old Jul 9, 2009 | 10:31 AM
JimzSS's Avatar
The belt slip and knock are good places to look too.
The bbv has a hose the runs to the bbv solinoid....unhook this line and plug it with a golf tee or the like.
See how it acts. Don't leave it like that for ong because the car bleeds boost for safety reasons.
Old Jul 9, 2009 | 10:59 AM
hymer741's Avatar
i just did some pulls on the way to work and my interceptor read knock retard at: 5.8, 3.2, 2.9 near redline...
What's that mean?
Thanks for the help so far fellas!
Old Jul 9, 2009 | 11:07 AM
JimzSS's Avatar
Its pulling timing up top.
typical if it in boost with lower octane fuel or iat2 are above 140*
I hope an expert will chime in,lol.
Old Jul 9, 2009 | 12:08 PM
hymer741's Avatar
lol me too
i use Shell 93 only
bump.. anybody else??
Old Jul 9, 2009 | 12:12 PM
ShortStack's Avatar
Almost 6 deg of knock retard is not good... you need a retune...
Are you hearing any other sounds? Belt slip has a loud screech associated with it...
What type of exhaust? cat or no cat?
Old Jul 9, 2009 | 12:16 PM
slowswap's Avatar
Thats a lot of knock retard. Check your plugs for signs of detnation. Sounds like something is wrong with the tune in the top end.
Old Jul 9, 2009 | 12:23 PM
rnjmur's Avatar
What's that mean?
That is alot of knock. I would definately start by looking at the tune and getting rid of the knock first. IAT2 at 120* is good, so you may need to add more fuel or drop the timing a bit.
Old Jul 9, 2009 | 12:24 PM
ShortStack's Avatar
Yea deff not the air temps doing it.
Old Jul 9, 2009 | 01:56 PM
hymer741's Avatar
I'm running the zzp midlengh combo, catted. 2.5 all the way trough
and no i have had no screeches, that's why i didn't initially think it was my belt.
alright. thanks guys. i'll pull my plugs and go from there.
Old Jul 10, 2009 | 01:11 AM
hymer741's Avatar
ok, just pulled the plugs and 1-4 looked good.
had no signs of running lean or anything.
any other suggestions??
t's not really doin it much anymore.
i think i just got some bad gas somewhere. i re-fueled today, and it hasn't done it since.
but i'm crossing my fingers lol
Old Jul 10, 2009 | 12:29 PM
JimzSS's Avatar
Keep us posted on how it goes.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
