Brake Fluid Low
Old Feb 3, 2011 | 11:57 AM
joeyblaze's Avatar
Brake Fluid Low
i will randomly get a brake light on the DIC and the car will say brake fluid low , then the ESC light and ABS light comes one. Now some time they will stay on, and some time they will just away, some time the brake light will go away but the esc stays on
If i stop and turn the car off, and re start they will all go away and be fine
seems to all happen randomly. Any one have this issue
Old Feb 3, 2011 | 11:59 AM
Chevycobaltss3's Avatar
first of check your fluid, if that is all good, i say either your level sensor is bad or, you have a eletrical issue.
Old Feb 3, 2011 | 12:14 PM
YEW FAIL's Avatar
what this guy said
Old Feb 3, 2011 | 01:59 PM
joeyblaze's Avatar
There didnt seem to be a fill line on the brake fluid reserve, also the peddle thro seems normal and so does stopping.
Old Feb 3, 2011 | 02:07 PM
insylem's Avatar
Pads worn out, causeing low fluid?
Old Feb 3, 2011 | 03:31 PM
joeyblaze's Avatar
it was a lose fitting on the back rear..... should be good to go. thanks guys
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
