busted flex pipe?
Old Aug 7, 2010 | 08:50 PM
shortyhend2004's Avatar
busted flex pipe?
Well my 06 ls busted one and now my wifes has. 50,000ish miles and its broke almost all the way around. Will this be covered under the 80k catalytic convertor warranty?
Old Aug 7, 2010 | 08:55 PM
Dart_SI's Avatar
well if the cat is damaged or if it affects the cat (assuming it does) then the dealership should replace it. as long as your not crazy modded your good. if not, its an easy fix. just buy another flex pipe and weld it on where the old one is. shouldnt cost u that much.
Old Aug 7, 2010 | 10:37 PM
Malaclypse's Avatar
It'll be covered. No big deal.
Old Aug 8, 2010 | 11:12 AM
BLKLS's Avatar
Not covered, the cat will only be covered if it has codes or is damaged. I went threw this maybe 6 months ago, went to/called 5 dealers no one would cover it because the cat was functioning. I ended up buying a new flex pipe and wielding it in.
Old Aug 8, 2010 | 02:33 PM
Malaclypse's Avatar
Huh.. I guess it depends on who you ask. I've always just put cats on cars that come in like that. Haven't had my ass chewed out yet.. *shrugs*
Old Aug 8, 2010 | 03:29 PM
BLKLS's Avatar
They are cover by the factory warrenty but not the 8/80 emissions.
Old Aug 8, 2010 | 07:02 PM
Malaclypse's Avatar
I'm saying I've replaced cats with busted flex-pipes under 8/80k. Its kind of a known problem on these Ecotecs anyways.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
717ssbalt
Oct 2, 2015 04:01 PM
z28addiction
Sep 28, 2015 12:03 AM
