A/C just stopped working
Ok so i was driving to work today and its like 100 deg. out-side, i have my a/c going full blast, then all of asuden i start to feel hot air. I look down and my a/c is still on but hot air is comming out. I try turning it off then back on but still nothing. When i got off the free way i restarted my car but that didn't seem to work eaither. Any one els have this same problem?
I had the same thing happen last year
Turned out there was a small leak from factory at the condensor and all the R134a leaked out
Replaced the O-ring - working perfectly ever since
LB
LB
you can do a visual inspection your self if you have a ss sc then all your plastic engie cover crap isint there if not you can remove and check all your lines etc yourself and find the problem so you ont have to py for them to reharge and pressyre test etc to find it if you ned some help locating these lines pm me or something but like Like_Budda sadi is probally you lost your charge of freon
Well my leak was out front at the condenser fitting had to replace the o-ring seal and recharged and it's been 100% ever since
It was all covered under warranty I didnt have to pay anything, in fact I did the work myself and GOT PAID to do it!
