Camber Help
Old Apr 18, 2009 | 05:11 PM
SlowBalt_06's Avatar
Camber Help
My struts are blown so i bought coilovers..before i bought them i went down to get an alignment and my front is off a pretty good amount...all they could do is grind some **** so it would work..so i told them not to do it..now that i bought the coilovers..should i buy new camber bolts to go along with them or will i not need them?.car does pull and bad tire ware
Last edited by SlowBalt_06; Apr 18, 2009 at 05:11 PM. Reason: Automerged Doublepost
Old Apr 21, 2009 | 03:10 PM
Old Apr 21, 2009 | 05:53 PM
DaBuzzard's Avatar
First step is to determine what is causing your alignment problems. If it is just the struts themselves then the coilovers should fix you up. You may or may not need camber bolts.
If something else is bent (car ever hit?) or worn out (control arm bushings?) then you have other issues to deal with.
Either way, you will want to get it aligned after you get the coilovers in and set your ride heights.
thmotorsports
18
Nov 5, 2007 05:04 PM
thmotorsports
THmotorsports
May 4, 2007 10:50 PM
red_wing_2121
Nov 13, 2006 05:28 PM
Badmunky
Nov 13, 2006 05:21 PM
jaslowyota
Apr 11, 2006 02:08 PM
