Cant open trunk
Old Mar 16, 2014 | 01:07 PM
MasonSS's Avatar
Cant open trunk
alright so heres the problem.. had battery out of my car as i didnt drive it this winter and today i went to go put the battery bak in but i cannot get the trunk open.. the key wont woke for some reason i tried lock deicyer and everything.... is there any other way to do it
Old Mar 16, 2014 | 01:13 PM
06cobaltncng's Avatar
your trunk pop button by the steering wheel not work either? crawl thru your back seat and pull the emergency latch.
Old Mar 16, 2014 | 01:19 PM
MasonSS's Avatar
how do you get backseats down
Old Mar 16, 2014 | 01:31 PM
theres a way somehow. I believe anyhow. just hafta look around. if it wasnt raining id go look.
cobaltsssc760's Avatar
inside trunk......
Old Mar 16, 2014 | 01:32 PM
You have to pop the trunk to get the back seats down haha
Old Mar 16, 2014 | 03:14 PM
This
Old Mar 16, 2014 | 03:18 PM
DaBuzzard's Avatar
Open the hood, hook up a battery as it you were boosting it, press release button on fob or dash. ..trunk should pop open.
blu3_v1p3r's Avatar
trunk pop button wont work with the battery out.
Old Mar 16, 2014 | 03:19 PM
blu3_v1p3r's Avatar
I was just thinking the same thing, just use another car hook up jumper cables, unlock everything.
Old Mar 16, 2014 | 03:21 PM
Yeah theres a positive battery post under the hood. You can hook up a charger to that and put the negative on the block or chassis.
Old Mar 16, 2014 | 03:49 PM
cobaltss#01's Avatar
what they said.
Old Mar 16, 2014 | 04:25 PM
dang I would have sworn you can let the seats down from the front lol
Old Mar 16, 2014 | 05:05 PM
MasonSS's Avatar
good idea, i cant pull another car up to where it is but ill try jumpingf with just the battery.. will let you guys know how it went in a bit
Old Mar 16, 2014 | 05:10 PM
REDi DEViSTATOR's Avatar
Omg.. Our future is in the hands of these free thinking people.. "what do I do if the electricity dependant button doesn't work cuz MY BATTERY IS OUT" I weep for your father. :-P
Old Mar 16, 2014 | 05:13 PM
Here's what I would do if your key don't even work, take a lighter... Pull down on the ignition for the lighter and start the flame, put key in flame, heat key up "not red hot" and slide into lock. Unlock car..
Old Mar 16, 2014 | 10:07 PM
Balt_2.2's Avatar
A friend of mine had the same problem. If your arm is long enough, you can reach between your seats to let one of the seats down and then crawl in the trunk and pull the emergency latch to get the trunk open. I've done it and I know it works. Hope this helps.
Oct 13, 2015 09:32 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
soaxin
Sep 26, 2015 08:41 PM
soaxin
Sep 26, 2015 08:39 PM
