car bogs under any throttle after rain
everytime it rains car sits in the rain not even driving in the rain it will start but as soon as i hit the throttle it bogs out and motor shuts down. last time i towed it to the dealer they wanted 300 to just diagnose the problem im assuming my maf might have gotten wet? im not sure if that would be the problem i have an injen intake on my 07 ss/sc with ottp stage 2 heat exchanger, ottp longtube and 3 inch cat back, with 60# and 2.8 pulley idk what to do i just had it hp tuned deleted the 02 sensor code dont know what else to look for getting tired of having it in the shop all the time any help would be great before i end up trading it in
p1113 is caused by a bad sensor
p1101 is caused by the maf sensor
po507 is high idle
p0300 is random misfire
did your maf sensor get wet? your maf sensor might be causing 3/4 of your codes, i dont know how the misfire comes toghether with the codes, are you running like crap? if you are your maf sensor might be toast and not sending enough information causing p1113 to come up
po507 is high idle
well no it actually is running good...when it runs but those codes were before the retune still misfires i dont think my plugs are gaped right do you think i should replace MAF i dont know how it would get wet car didnt move in the rain just sat outside didnt run over a puddle or anything
well was going to drive it home and clean the tb and intake had to leave it in a parking lot over night thats what i did last time and the next day it was fine ever since so today it was still doing the same thing i have no idea what to do had it towed to a shop anyone have any ideas
so i picked it up at the shop they tested just about everything i dont know what it could be i put new plugs in it see if it does it again if so i guess ill trade it in i dont have any other choice
Turbo Johnny
Feb 21, 2019 09:41 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
