car is down again!!!!!!
Old Dec 9, 2007 | 07:54 PM
jimbos'ss's Avatar
Thumbs down car is down again!!!!!!
well i just got done installing a new motor and trans, after the last motor blew. so i was on the way home from work the other night and all of the sudden i lose boost alltogether, and the car feels very sluggish. a few seconds later the low oil pressure light and the low voltage light come on. so i pull over and pop the hood. the serpentine belt was not moving at all. so i jack the car up and low and behold the crank pulley is spinning freely. i torque it down and drive home. by the time i get there. same problem occurs again. so i'm like wtf..... well a little while ago i went out to work on the car and see if i could fix the problem. as soon as i pulled the crank pully off, i realized it was going to be a very bad day. the damn shim for the crank pulley snapped. i know why too, the ******** mechanic that installed my motor and tranny failed to torque down the crank pulley. so now i have to pull the motor to get the cover off to replace the damn shim. you can't ******* trust mechanics to do such simple ****!!!!!!!! wtf over.
/end rant
Old Dec 9, 2007 | 07:56 PM
DTM2188's Avatar
Sorry to hear man. On the bright side, it wasn't anything overly major I guess.
Raven SS's Avatar
damn jim...
Old Dec 9, 2007 | 07:57 PM
nightstalkercars's Avatar
sounds like a realy bad day damn sorry dude
Old Dec 9, 2007 | 07:59 PM
stryder's Avatar
take em to small claims
Old Dec 9, 2007 | 08:00 PM
GreenPurgatory's Avatar
Yeah, atleast you figured it out right away!
Old Dec 9, 2007 | 08:04 PM
jimbos'ss's Avatar
yeah, thankfully, cause if it had caused the new motor to blow i would have walked down to that ****'s shop and broke his neck.
Old Dec 9, 2007 | 08:07 PM
Jimmys2007CobaltSS/C's Avatar
damn dat sucks man
Old Dec 9, 2007 | 08:12 PM
IonFeright's Avatar
Sorry to hear this Jimbo.
Old Dec 9, 2007 | 08:15 PM
jimbos'ss's Avatar
well at least it's not as bad as the situation your in. mine is at least fixable, i just don't know when it will get done. it's really messing up my turbo plans as well as my vacation plans for christmas.
Old Dec 9, 2007 | 08:18 PM
IonFeright's Avatar
yeah you have a point but when its down, its down. Even if its fixable it still blows.
Old Dec 9, 2007 | 08:20 PM
Sharkey's Avatar
did you have a new (as in new crate engine from gm) engine put in, or a used one from the junkyard??? did your mechanic actualy touch this part??? if it was a used motor, id venture to guess no. even if it was a new motor, wouldnt it come with the crank pulley. regardless, you likley have a warrenty and if it is in fact the mechanic that messed this up, im sure he will cover it. if it was a used motor, usually the place the motor came from will warrenty it, but not the labour to re/re the engine.
talk to your mechanic, CALMLY. yelling and screaming at him will get you no were, and its disrespectful, especially if the problem isnt their fault.
Old Dec 9, 2007 | 08:32 PM
jimbos'ss's Avatar
no the motor was bought used from a guy on this sight. and i know the mechanic touched it because i had him swap all the accesories from the old motor to the new one which had no accesories on it.
Old Dec 9, 2007 | 08:47 PM
Sharkey's Avatar
woulodnt really count the crank pulley as an accessory. id almost bet that if it had a crank pulley on it he wouldnt have changed it. however, if he did, its his fault and he should be fixing it for you free of charge.
Old Dec 9, 2007 | 09:02 PM
jimbos'ss's Avatar
his fault or not, i'll never let that guy touch my car again, there was so many things i had to go back and fix when i got the car back from him last month. it was terrible, he had the baro sensor cable hooked up to the scip sensor, misaligned my exhasut, and a bunch if other problems. on top of the fact he charged me double the cost he quoted me just because the car has and sc on it(like that really makes the car hard to work on.)anyhow i've got a decent guy in mind to fix it for me. this is why i hate living in an apartment. if i had a garage i could have done all the work myself, and made sure it was done right.
sorry for the rant guys, i'm just tired of the constant problems i've been having.
Old Jan 4, 2008 | 02:48 PM
jimbos'ss's Avatar
update, so it was not just the crank puleey and shim that was fucked up, the crankshaft itself has a chunk missing, and the cam drive gear is fucked!!!!!!
how the ****.........i only got 400 miles out of this ****** motor.
Old Jan 4, 2008 | 02:52 PM
Rangerondubz's Avatar
Holy *****, sorry to hear that man, so was all of this caused from the mechanic?
Old Jan 4, 2008 | 02:55 PM
jimbos'ss's Avatar
either that or the motor was allready messed up when i bought it used off a member on here.
Old Jan 4, 2008 | 05:20 PM
Raven SS's Avatar
damn jim..i hope things work out
Old Jan 4, 2008 | 05:27 PM
thedubsack85's Avatar
x2.. man that suck's.. why was the person selling the used motor? and if the greese money swapped all the motor accessory's he is at fault.. cause if the crank pulley was spinning free it damaged a few other thing's as you can see.. hope all works out well
Old Jan 5, 2008 | 04:15 PM
jimbos'ss's Avatar
thanks for the support guys, i might get it warrantied after all, find out monday or tuesday
Old Jan 5, 2008 | 06:16 PM
IonFeright's Avatar
good luck Jimbo. I just got word that GM wants another 1-2 months to figure out whether or not Ill be covered under warranty. Hopefully things move quicker in your situation.
Old Jan 5, 2008 | 06:20 PM
turboeco's Avatar
I'll take your LSD trans, if you get the ***** of it all.
Otherwise goodluck, I've had my share of downtime.
Old Feb 2, 2008 | 12:14 AM
jimbos'ss's Avatar
well warranty was a nogo, i just ordered all the parts to build a full forged motor with an 8k rpm redlin. wow was that ******* expensive, i will also be cryo treating the whole thing for added assurances.
Old Feb 2, 2008 | 02:45 PM
stryder's Avatar
pm me about cost so i know what to look forward too, im sure you got some decent deals. Oh how much do you think it would cost to cryo some stock axles and how much strength would that add to them IYO
