car not starting. help please
Ok my girl has a 91 honda accord ex. it hasn't been started in 2 years. i changed the oil, ignition coil, spark plugs, wires, distributor rotor. it gets spark (pull them out turned it over, got spark). well i tried to start it. no luck. i spayed starting fluid, flames came out of the throttle body (think i spayed to much). so any opinions.
just shot flames. and battery is dead. i been jumping it. i think the flames came out because the guy was starting it kept hittin the gas pedal (told him not to do that because i thought he was going to flood the engine) so when he didn;t press the gas and we sprayed it, it would make a poping sound and white smoke would out of the TB.
when i usually spray **** into the engine through the throttle body, I usually floor the car until it starts, i have found out it works better than laying off the gas all together, **** i had to to it today at work with some starter fluid myself.
but check the basics.
Spark, Injector pulse, Fuel etc
no.. nothing.. im going to go over today and try other stuff.. o and i put new gas in it.. im going to triple check the wire since i have the acutual honda drawling to make the the wires are in the right place on the cap.
