fing cels & reverse lights
Old May 3, 2008 | 09:42 PM
flathead0's Avatar
keep throwing cels so is anyone in the san francisco area with hp tuner that can take a look and the reverse lights do not work bulps are good and so is the fuse so i know i need to take it to the dealership for that, so anyone in the bar area with hp tuner
Old May 3, 2008 | 09:43 PM
SlowBalt_06's Avatar
probly just from the highflow cat...
Old May 3, 2008 | 09:44 PM
flathead0's Avatar
that **** is just annoying as all hell to look at all the time
Old May 3, 2008 | 09:48 PM
yea just unhook the battery for 10 mins and you'll be fine
Old May 3, 2008 | 10:16 PM
Ducky22287's Avatar
What does that do? You got me curious lol.
Old May 3, 2008 | 10:18 PM
MikeyMo84's Avatar
lemme know what the reverse light issue is cuz i just noticed that mine dont work...changed the bulbs and everything...what # is the fuse and where is it located??
Coblasts's Avatar
The reverse light issue is most likely your switch,located on the tranny,Ive heard that they fail.
Backup Lamp Switch (w/M86) located Left side of the engine compartment, on top of the transmission
What are the codes that you have.
Then maybe someone on here can help you.
Old May 4, 2008 | 07:22 PM
donjuaniii's Avatar
I have the same issue with my reverse lights .... Left side of engine compartment - from the front or as if sitting in car?
Don't happen to have a picture do you ?
Thanks
Old May 4, 2008 | 08:32 PM
flathead0's Avatar
dont know how to post pics but it shows you were in the owners book i dont know what cel its throwing i think i need someone with hptuners. i have tryed disconnecting the battery it works for a little bit but then the cel come back
Old May 4, 2008 | 11:29 PM
Video2402's Avatar
The reverse light issue is most likely your switch,located on the tranny,Ive heard that they fail. Backup Lamp Switch (w/M86) located Left side of the engine compartment, on top of the transmission.
Blah! I just replaced mine today and my reverse lights still dont come on damn
Old May 5, 2008 | 02:10 AM
MikeyMo84's Avatar
left as in drivers side i guess? seeing as thats where the trans is...what does it look like...can you be more specific??
Old May 5, 2008 | 08:28 AM
Video2402's Avatar
it is in a really bad spot! if you reach your had right next to the fuse box and down to the transmission, you've found it. Right where all the wires are ran.
Old May 5, 2008 | 10:26 PM
donjuaniii's Avatar
What did you have to remove to get to it...?
I'm guessing - taking off driver's front wheel & fender liner to get to and remove the engine compartment fuse box ?
There's a thread where someone replaced a roll pin in their transmission linkage and basically had to remove all that to get to the pin - I'm guessing that it could give access to the switch at the same time...
https://www.cobaltss.net/forums/how-guide-43/how-fix-linkage-roll-pin-transmission-102830/
Old May 6, 2008 | 01:07 AM
Video2402's Avatar
I did not remove anything.
Old May 6, 2008 | 11:43 PM
donjuaniii's Avatar
Damn...you must have some skinny arms/small hands....
Is the switch held down by anything?
How does it dis-connect?
I just can't see how I'm going to be able to get to it (let alone even see it) without removing something....but I'll try.
Old May 7, 2008 | 01:03 AM
Video2402's Avatar
I used a long ratchet, with a deep socket. which were 'skinny'. yay.
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
