Car shut off at full throttle in 2nd on highway
Old Mar 15, 2008 | 09:47 AM
Rodimus_Prime's Avatar
WTF!
SO I was pulling on the highway and had it wide open in 2nd gear at 5k or so rpm and the car feels like it hit a rev limiter and then shut off
I pulled off tried starting it back up and it tried but just died
Let it sit for 2 min now its working again
What the hell?
Old Mar 15, 2008 | 09:58 AM
06blackg85ss's Avatar
aaah the wonderful world of cobalts..
PCM freaks out every now and then and does that... bet you got a p00068 code (or whatever it is for the correlation ****), If you know someone with hp tuners, go to DTC's and change the set rpm to 8k, wont happen again.
Herndon_High_SS's Avatar
Same exact thing happend to me too. Going about 100 and bam car shuts off. Called onstar and they said it was a throttle positioning sensor. Idled like a wrx....Thought there goes the piston rings...but let it sit for 5 mins off and good as new.
Old Mar 15, 2008 | 10:00 AM
im not sure if the tune thats in there right now has that but I know the reflash thats waiting to go on has the P0068 test set to 8k
From doing some reading up on here it seems like i might have hit the inertia switch? But I didnt hit any bumps, I was going up a slight hill and the car does throw you back a lil under full load but it wouldnt seem enough to trip this
Old Mar 15, 2008 | 10:01 AM
nah no inertia switch man.
Old Mar 15, 2008 | 10:04 AM
biohazard's Avatar
Get low
ya only fords have those
Well just did a code check, no probs at all
Old Mar 15, 2008 | 10:18 AM
How's it running now? Mine only took abut 5mins being off and then ran like a champ after that.
Old Mar 15, 2008 | 10:19 AM
Seems to be fine, I havent taken it over 4k, im kinda scared to
Old Mar 15, 2008 | 10:26 AM
If it feels fine just give it a few small pulls. It should be fine. Sounds EXACTLY like my situation and mine turned out fine. Good luck.
Old Mar 15, 2008 | 10:29 AM
How often does this crap happen, I dont want to you know be pulling out ahead of cars going 70mph and get rear ended because the motor keeps dying
Old Mar 15, 2008 | 10:35 AM
Not very often I believe. It happends very rarely. Happend once to me and I highly doubt it will happen again.
Old Mar 15, 2008 | 10:36 AM
KandelSS's Avatar
same thing happened to me in second gear...mine just lost all my gauges first then i pulled over and it just shut down, tried to start and wouldnt try at all...then waited like 5 mins and worked right away, never happened since
Old Mar 15, 2008 | 10:42 AM
sick06cobalt's Avatar
my guess is guys that it could have heat soaked and went into limp mode... it wouldnt surprise me....
Old Mar 15, 2008 | 10:44 AM
My car threw the throttle positioning sensor code though....
Old Mar 15, 2008 | 01:29 PM
Limp mode isnt shutting off the car though
its 50 degrees out and coolant temp was like 176 car was only running for a few min
Old Mar 15, 2008 | 01:58 PM
See it still sounds exactly like my situation....I remember the car saying ENG PWR REDUCED and then shut off while driving.
Well who knows...
Old Mar 15, 2008 | 02:07 PM
2fastSS's Avatar
Mine did the same thing but i was stopped...I had revved up my car because the lady next to me was being a complete douche bag by turning her music all the way up, light turned green i revved it up kinda high and bam the ****** went to like 500 rpms weird ass idle and just shut down on me.... I went to turn the key a few times, and it just clicked nothing happened....waited a few minutes and it was good to go never did it again....
Old Mar 15, 2008 | 02:09 PM
well limp mode or (power reduction mode) will shut off the car... ive experienced it ... its not fun lol... but yeah i dont have another guess if your coolant was at 176
Old Mar 15, 2008 | 02:23 PM
jekqmb's Avatar
Hahaha my car always did this when i had carbon build up caked on the TB, clean your MAF and TB and see if your car runs alittle better.
Old Mar 15, 2008 | 02:27 PM
ItalianJoe1's Avatar
Its a bad Crank position sensor from what I figure. It has happened to me a total of 3 times, first time the car started up again while coasting down, second time it had to sit for a few minutes, third time I sat for hours and got towed home, then when I tried it after I got home it started. This all happened over the course of almost a year, not back to back. I've since changed the sensor, hasn't happened again. It has only been a few months though...
Old Mar 15, 2008 | 05:10 PM
part number on that?
how hard is it to change
Old Mar 15, 2008 | 08:09 PM
Don't have the part number at hand, would have to go through my stash of parts in the garage to find the old one in the bag. Its about a 15 min job, it sits right below the oil filter on the front of the block, one 10mm bolt holds it. Easy, just don't drop the bolt, it gets stuck on top of the starter and is a bitch to get out.
Old Mar 15, 2008 | 08:19 PM
DoMiStIc_RuSh_06's Avatar
Sounds like everyone is experiencing the same thing that I have last summer. It happend to me 3 times over the course of 3 months. After the first 2 times, I changed the crankshaft position sensor, and it happened the third. The first time was in the middle of a busy highway, pulling out from a side road, there was traffic coming both ways towards me lol....Scary i know that!!
Old Mar 15, 2008 | 11:24 PM
anyone have a pic of where this is on the motor
