Car will not warm up!!!
Old Feb 4, 2014 | 07:54 PM
volsfan92's Avatar
Exclamation Car will not warm up!!!
My car generally will not get above 130 F coolant temp unless I let it sit for awhile in this cold weather..Even when its warm outside it still struggles to get 160..I replaced thermostat a while back and it fixed issue for a few weeks then it came back..Any help would be appreciated
Old Feb 4, 2014 | 08:23 PM
rivaladore's Avatar
Did you put a pos oem tstat back in there? Chances are that one crapped out too.
Old Feb 4, 2014 | 08:30 PM
TStone's Avatar
i'd say more than likely it's a thermostat
Old Feb 4, 2014 | 08:34 PM
ItalianJoe1's Avatar
Has to be a thermostat, it's the only thing that can fail and not allow the car to warm up properly.
It's possible your engine temp sensor is failing but they rarely fail and only read incorrectly by a little, they usually die completely
rico's Avatar
I'm having this problem with my redline . Sometimes it warns up sometimes don't go past 113 or 130 .
Ordered a thermostat from zzp let's see what happens after I put it on
Old Feb 4, 2014 | 08:44 PM
volsfan92's Avatar
I think if I remember right I put an autozone tstat in it..any certain one i should try if they wont warranty it?
Old Feb 4, 2014 | 08:59 PM
TStone's Avatar
acdelco
just noticed zzp has them on their site for 15 bucks
Old Feb 4, 2014 | 09:10 PM
iToastie's Avatar
Get ACDelco
Old Feb 4, 2014 | 09:13 PM
volsfan92's Avatar
Ok i see it now
Old Feb 4, 2014 | 09:22 PM
rivaladore's Avatar
I went with a duralast from autozone. Usually don't buy that stuff but it looked more durable than the oem one and I wanted to avoid buying another crappy oem one. Had it in for 30k so far and no issues.
Old Feb 4, 2014 | 09:49 PM
volsfan92's Avatar
Maybe they will take it back but I highly doubt it..my gas mileage is horrible
Old Feb 4, 2014 | 09:53 PM
BlackielawlessSS's Avatar
My bmw did this. It was the t stat.
Old Feb 4, 2014 | 09:56 PM
05g5's Avatar
^ becauze the motors cold, so it loads that motor with fuel to try and warm it up but it does get warm..
Make sense? Haah
Called open loop, when it reachs operating temp it goes into closed loop
Your not losing coolant are you? No excessive pressure in cooling system?
Old Feb 4, 2014 | 10:01 PM
redcobalt07's Avatar
$15 for a thermostat is way to expensive. rock auto they are like $3
Old Feb 4, 2014 | 10:02 PM
blu3_v1p3r's Avatar
mine would read intermittently, some days it would read just fine then other days, it would trip the CEL and just show "---" for the coolant temp. I changed both the T-stat and the temp sensor, and fixed everything.
Old Feb 4, 2014 | 10:11 PM
volsfan92's Avatar
Im not losing any coolant or anything...I'm gonna replace it this weekend I guess for the second time
Old Feb 4, 2014 | 11:36 PM
Ouch. Did you replace with oem the first time or no?
Old Feb 4, 2014 | 11:53 PM
volsfan92's Avatar
I honestly cant remember..Im pretty sure it was a duralast or whatever autozone sells..Im gonna pull it out and hopefully it says brand but i doubt it
Old Feb 4, 2014 | 11:55 PM
Yeah the "---" is it not reading properly, that's for sure the sensor or a wiring issue like my car had, the harness got cut through rubbing on something and shorted out to ground intermittently, resulting it the sensor reading 300+ degrees or just dashes sometimes, worse when it was wet out.
Old Feb 5, 2014 | 09:12 AM
Stop buying from Autozone. I learned a long time ago, all of there parts are straight junk. I had 3 alternators fail, and countless other parts fail Coil packs that were bad out of the box. Find somewhere that sells american made parts. Oriley if you absolutely have no other choice.
Old Feb 5, 2014 | 09:34 AM
umrdyldo's Avatar
Lol, too bad most of our parts are made overseas. American made LOL, good joke.
One thing I do agree on, O'Reilly Auto Parts. I help design stores for them and they seem to have their **** together. That's why they are growing so fast.
Old Feb 5, 2014 | 10:40 AM
I can get my hands on american made parts. moog and standard still. Orileys and NAPA are the best chain places to buy parts. I needed a coil pack for my F150, Granted it was the old 4.6 2v with the coil pack block of 4, if that makes sense. Anyways I was running low of money, as it was winter time. Bought a duralast one. Came home, put it on and it wouldn't start. I finally got it to start and it was missing like crazy. So after looking up the wiring diagram and making sure I didn't do something wrong, I put the old one back on, and it fired right up, and wasn't missing nearly as bad. I took it back, and they told me yeah, we get a lot of parts that aren't good out of the box. Then why sell them? I have not bought anything other then a bulb or cleaning stuff from them since.
Old Feb 5, 2014 | 01:27 PM
tomj77's Avatar
I think the first question I'd ask is how cold is ur cold and what temp do u consider warmer outside. Also, how long u driving when u notice this?
Old Feb 5, 2014 | 09:39 PM
volsfan92's Avatar
By cold I mean 30 or below and warm I mean 50 or warmer lol I can drive for 30+min and won't go over 150 when it's warm unless it sits forever
Old Feb 5, 2014 | 11:43 PM
tomj77's Avatar
id say temp sensor. try this if u can, take out temp sensor. boil some water, leave temp sensor connected and put it in the water and see how hot ur car says that is. probably want to use a thermometer to check the water first to see if it matches up.
chefhhr
Oct 26, 2015 10:36 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
Sabon_SS
Sep 7, 2015 12:39 PM
