car wont start
Old Jul 30, 2012 | 10:31 PM
G11's Avatar
G11
car wont start
Just got my car back together got it running and was driving around. Someone bought the car and took it. On his way home it started acting funny and came up with a p1133 at first. He then tried to clear the code by unplugging the battery. Got it cleared and tried to start it and nothing. Then came up with a p0096 and p0116 and p0111. Cleared those and then the security light came on. Got the relearn done and still no start it cranks but won't kick over
Old Jul 30, 2012 | 10:33 PM
Chevycobaltss3's Avatar
look at the ip fuse in the engine bay!!!! And make sure the grounding is good!
Old Jul 30, 2012 | 10:40 PM
G11's Avatar
G11
Fuse is good and grounds are connected good
Old Jul 30, 2012 | 10:48 PM
well if the car wont even click, then the security is screwing you over..!!!
Old Jul 30, 2012 | 10:50 PM
G11's Avatar
G11
Cranks but no start
Old Jul 30, 2012 | 10:52 PM
Push start the car .. If no go, then its gonna be fire or fuel (check the fuse for fuel injection as well) ... So it can be the cam sensor etc!
Old Jul 30, 2012 | 11:30 PM
northvibe's Avatar
I was thinking fuel pump, but check what chevycobalt said.
Old Jul 30, 2012 | 11:38 PM
G11's Avatar
G11
There was no pressure at the fuel filter changed and now have pressure and crank but no start.
Old Jul 30, 2012 | 11:45 PM
check for fire..!
Old Jul 31, 2012 | 12:27 AM
G11's Avatar
G11
I know I have spark, I know I have air, I know I have fuel, it cranks but still no start
Old Jul 31, 2012 | 03:10 AM
Aleksey's Avatar
Sure you're getting fuel through injectors?
Old Jul 31, 2012 | 05:22 AM
scotch89's Avatar
i cant remember the code i threw, but when i swapped my stock injectors for 60lb during my whole stage 2 process, i couldnt get my car to start after. it would crank but wouldnt start. on the fuel rail there is a pieace that is pressed on i belive. any way when i went to tighten the fuel rail back up i ended up moving that pressed pieace. wich then didnt get pressure or air was leaking to it (idk exactly) but narrowed it down to that, and ended up JB welding that pressed pieace, letting it cure and then it started right up. few days later got a used fule rail swapped it and it started up. i know your de-modding your car so i thought this might help
Old Jul 31, 2012 | 10:16 AM
G11's Avatar
G11
I had the fuel rail out and cranked it to make fuel was coming of each injector and I do. It was running for most the day when I drove it. I then sold it and a half hour later this **** started to happen. Possible pcm?
Old Jul 31, 2012 | 10:18 AM
if you have fuel and fire ( and still no start, then its possible plugs are to fouled or the fire isnt enough aka to weak).
Old Jul 31, 2012 | 04:44 PM
G11's Avatar
G11
Ended up being the grommet that holds the fuel pump to the line in the canister. It was torn which in turn was causing it to bleed of pressure so no start
Old Jul 31, 2012 | 06:21 PM
scotch89's Avatar
Good you got it figured out
hawkssoccer11
Sep 30, 2015 12:14 PM
Wind
Sep 11, 2015 06:57 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
