car wont start after recall work...
Old May 24, 2014 | 06:10 PM
goaliemo's Avatar
so, go to take the car out on this beautiful day. and she wont start!! I got her back Tuesday from having the ignition recall fixed.
The car clicks, the dash lights up, and the cd player sounds like its trying to spit a disk out. I am assuming its the ignition cylinder that was just replaced.
when I got home last night, I pulled in the driveway (in my sedan) and noticed the passlock light was flashing. went to take the RL out today, and this is what happens.
so at the moment, im assuming its the ignition.
I know the other option is the start, or the crank fuse.
How do I tell if the crank fuse is bad?
I am trying to check as much as I can myself, before I let chevy molest it.
The only reason it will go there, is so they can fix it if it is their fault. otherwise I want her going to my mechanic.
Old May 24, 2014 | 07:01 PM
goaliemo's Avatar
I think instead of me getting aggravated with this, ill just have her towed to chevy Monday morning, and make them fix whatever they messed up.
Old May 24, 2014 | 07:04 PM
LNFTX's Avatar
Dead battery???
Old May 24, 2014 | 07:32 PM
goaliemo's Avatar
nope, battery is fine. checked that. all the dash lights come on, the clock comes on, and when I try to crank it, all the lights cut off. I think its a shortage in the ignition.
Old May 24, 2014 | 11:59 PM
LNFTX's Avatar
Thats exactly what happened last time by battery was dead
Old May 25, 2014 | 12:14 AM
EmperorJJ1's Avatar
test voltage when cranking. its not as common but sometimes the batt will read good but when you crank it drops down to 9v or something ridiculous.
Old May 25, 2014 | 12:19 AM
goaliemo's Avatar
I tried using a battery box to jump it because I thought that was it. switched it to engine start, and nothing. im gonna try again in the morning, and test the voltage.
Old May 25, 2014 | 12:47 AM
Axelthered05's Avatar
sounds like a dead battery to me
Old May 25, 2014 | 12:58 AM
EmperorJJ1's Avatar
If you had it on engine start and gave it a bit to "charge" before starting it then its less likely it was the battery. Still possible though. Test it just in case because you dont want to have it towed to the dealer when turns out it is the batt so ud have to pay for the tow, diagnostic and whatever crazy price they have for an OEM battery
just very suspect if you had no issues before and all of a sudden it crapped out after taking it in to be serviced but who knows they could have left the lights on or something stupid
Old May 25, 2014 | 12:59 AM
rivaladore's Avatar
Your car has been on the road for 8 years, still have the original battery in there?
Old May 25, 2014 | 01:01 AM
rivaladore's Avatar
If the original battery has been in his car for 8 years then he deserves to pay for a tow.
Old May 25, 2014 | 01:11 AM
goaliemo's Avatar
Alright, I just bought the car a month ago.
I believe it is the original battery because it is an ACDelco, and the guy I bought it from said it never saw a dealership because he was a "mechanic". So, I am not 100% on it, but I don't see why another ACD battery would go in.
I did not have a problem with it starting until after the ignition was put in.
I did let it charge for about a half hour before I tried the engine start.
Guys, I'm just trying to learn, I'm a cook, not a mechanic. I am just trying to learn how to take care of and work on my car.
Old May 25, 2014 | 01:42 AM
kzak104's Avatar
Try bump starting it :P
Old May 25, 2014 | 02:02 AM
goaliemo's Avatar
if only my street wasn't so narrow :p
Old May 25, 2014 | 10:33 AM
Whitnith's Avatar
Did you get new keys when you got the car back? It sounds like they didn't program the chip in the key to the car.
Old May 25, 2014 | 12:11 PM
goaliemo's Avatar
I did get new keys, and we also asked if they were chipped because we need a third key, and we were told its not chipped 0.o
Im really thinking its a bad ignition, or they didn't do the passlock relearn.
Old May 25, 2014 | 12:15 PM
c0de7477's Avatar
i just changed my battery on my truck. was doin the same thing. battery was so bad you couldnt even jump it. looked like the original battery from 1990 haha. pretty sure it had bad cells.
Old May 25, 2014 | 12:21 PM
goaliemo's Avatar
when I put the box on it, it read good. I may take it down to autozone to have it checked better.
Old May 25, 2014 | 01:48 PM
LNFTX's Avatar
If key has a + sign with a little circle around it right below the black plastic part it's got a chip in it
Old May 25, 2014 | 02:19 PM
Whitnith's Avatar
Yeah, you need a chipped key, and one that is programmed to the car.
Sounds like that's the problem. You can do the relearn yourself, it's not hard.
Old Jul 17, 2014 | 11:09 AM
HeavenSent's Avatar
I have same problem
I have the same problem before I had the new ignition put in my Colbalt my car worked great no problems at all but now I have trouble with it starting to it just clicks at times and I had my battery , alternator and starter checked they are all in good working order so I know it is from the new recall ignition they put in please let me know if you have found out what the problem is
Old Jul 17, 2014 | 11:12 AM
GreenySC2's Avatar
i know when i did it a few weekends ago i had to take the two new keys(you can tell whats what due to the single little hole for the ring) and i had to learn them... its a simple process i cannot remember at the moment...
Old Jul 17, 2014 | 12:48 PM
goaliemo's Avatar
check the battery again. I took mine to autozone and they told me it was completely dead, when my battery box was reading good. so, just put it on a slow charger for a few hours and she started right up. haven't had an issue since.
hawkssoccer11
Sep 30, 2015 12:14 PM
Wind
Sep 11, 2015 06:57 PM
southal cobalt
Sep 9, 2015 08:21 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
