Car wont start eng pwr reduced
Old Apr 6, 2009 | 07:38 AM
Lovethesox's Avatar
my car has been sitting in my garage for about 2 weeks and I tried to pull it out yesterday and it turned over and then immediately died and now wont turn over at all. I have a redtop battery that isn't dead and i tried resetting the battery and that didn't help either. anyone have any ideas?? im over my warrenty and would like to at least try to fix it myself
Old Apr 6, 2009 | 09:11 AM
Coblasts's Avatar
If you have been starting it over the winter and letting it run and shutting it down the plugs are probably fouled,
Try changing them or cleaning them good.
Check your intake for a mouse nest but I would go with the fouled plugs.
Can you hear the fuel pump pressurize ?
Old Apr 6, 2009 | 09:12 AM
brickerenator's Avatar
maybe the battery is dead
Old Apr 6, 2009 | 09:13 AM
jonxxxedge1's Avatar
has it been sitting all winter?
Old Apr 6, 2009 | 09:16 AM
light'bolt's Avatar
x2 on the intake also check exhaust. Them little critters can do lots of damage. Eat thru wires etc. etc....
Old Apr 6, 2009 | 12:43 PM
Lovethesox's Avatar
its only been in the garage for 2 weeks tried changing the plugs didnt help it ran fine untill then and its def not the battery ive still got power to everything
Old Apr 6, 2009 | 12:54 PM
light'bolt's Avatar
check the fuse to the injectors. I've had that happen when it stalled out, don't know why the fuse blew but it did
Old Apr 6, 2009 | 10:30 PM
Coblasts's Avatar
Try boosting it anyway,you never know and its a free solution if it does start.
Old Apr 7, 2009 | 10:28 AM
Turbo06Sedan's Avatar
check for codes. go buy/rent a obd2 scanner
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
bucks121
Sep 12, 2015 07:39 PM
Wind
Sep 11, 2015 06:57 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
