Car wont start heeeeewwwwwwwllllppppp
Old Jun 12, 2011 | 01:40 PM
MastaShaKe_88's Avatar
Old Jun 12, 2011 | 02:11 PM
ryman416's Avatar
yeah you're gonna need someone with the right tools to check it out(dealer). my two cents is that upon the wiring of your headlights, you may have blown a fuse somewhere or the wires are short grounding(exposed wire from melting or tearing touches a metal part of the car and grounds itself before it gets to where it needs to go). that could be from doing the lights without disconnecting the battery. I think it is a purely electrical problem because with an 09, you shouldn't be facing issues with simple exhaust bolt-ons. thats my opinion. also try popping the clutch again because that eliminates the need for a starter. but as i said, we use some fancy tools here at the dealer i work at to diagnose things like this so find out bout warranty before you get fucked on dealer costs.
Old Jun 12, 2011 | 02:18 PM
thats wat im tryin to do now... I highly doubt this'll be covered under warranty, so I'm tryin to pinpoint the problem so if its unfixable from my side I can tell em EXACTLY wat it is..
I don't think its how I wired my lights tho.. this is my second set of Retros, and i did the ground/wiring almost the exact same way... If all else fails, Ima jus take off the relay an connections to battery an have it towed up there
Old Jun 12, 2011 | 02:41 PM
ryman416's Avatar
it also could be a security control module that could go bad. idk if cobalts have exactly what i see at work but a similar problem happens with no obvious electrical malfuncion because the module needs to send the engine codes upon start up so the injectors know they can spray, spark plugs spark, and yadda yadda yadda. if that module is bad, the engine wont know that it can tart running, and the starter will just keep cranking. usually problems like these are hard to fix on your own. but good luck anyway.
Old Jun 12, 2011 | 02:51 PM
how would i know if thats the problem?
Old Jun 12, 2011 | 03:00 PM
ericgt79's Avatar
you dont need to know the problem if you go to patriot, corey will fix your car and it will be under warrenty. just tell him your car wont start and the post just fell out of no where, not that corey will care because if you cant come up with a good enough story for GM he will do it himself, you will get your car fixed for free and he will get paid for the work by GM so everyone will win.
Old Jun 12, 2011 | 03:01 PM
ericgt79's Avatar
whats wrong with your car is YOU i told you long ago stop fucken with them lights and now you see why idiot. just take the car to Patriot and let corey fix it and stop being a fucken moron
Old Jun 12, 2011 | 03:10 PM
don't you have some people to arrest or somthin? I bet you're sittin in the shoppette parkin lot on yer phone right now chump I know Mps don't like to read much but I said I was gonna take it in on Monday anywaysssssss I blame yer bunk ass lights for all the problems in the first place lol
Old Jun 12, 2011 | 03:28 PM
EmperorJJ1's Avatar
if its security the lock light on the dash "should" blink. then again when my car was at the dealer they asked me why the security wasn't letting the car start. i told them my car started just fine before it got here so u better figure it the **** out and call me when your done
Old Jun 12, 2011 | 03:29 PM
ryman416's Avatar
with the previously stated fancy shmancy dealer equipment
  #36
ericgt79's Avatar
im in El Paso ****** so nice try
Old Jun 12, 2011 | 03:31 PM
  #37
EmperorJJ1's Avatar
el po ftw!
  #38
lmao bet.. it does come on with the rest of the lights now as it didn't before, so that might be it.. im hopin its somethin simple... so it can be in an out an I can get back to drivin again an i can finish up my retros
Old Jun 12, 2011 | 03:33 PM
  #39
o yea...... not sayin I don't love you enough to keep track of your whereabouts or nuthin but uuhhh....
  #40
ericgt79's Avatar
your so stupid, the lights fucked up your car in the first place and you gona get it fixed and then continue to **** it up again with lights. smh winnar winnar chickan dinnar
Old Jun 12, 2011 | 03:37 PM
  #41
you crazy, you should be worrying bout keeping the brake dust off yer white wheels an less bout my lights lol
oh and uh....
I'ma call the dealership today, Im just a lil weary because I hooked up my retros an ran a wire to the positive post and I'm sure that wouldn't be covered under warranty...(And no I didn't break off the post when I hooked up) I broke off the old connector for my HIDs an got a bigger circle connector that fit right over the screw-on part)
hehehe...
Old Jun 12, 2011 | 03:45 PM
  #42
ericgt79's Avatar
just because it didnt blow the first time doesnt mean it didnt happen the second time. im telling you leave the lights alone, get some plug and play **** and call it a day, you need to worried about other **** anyway like why you car looks like a fucken semi truck and that lip thats 8 diff colors.
i hooked you up with all this info and other **** and yet you still insist on ****** your car up and nothing ever goes right, im just wondering when your gonna learn
Old Jun 12, 2011 | 03:50 PM
  #43
I never had any problems with my lights, lip'll get painted when i feel like shelling out for it, an i haz no problems with anything else on my car... like my wheels stayin on or my Turbo... *cough cough*
thanks for trollin up my thread tho
Old Jun 12, 2011 | 04:02 PM
  #44
ericgt79's Avatar
cough cough my car runs and has never stopped running cough cough and theres nothing wrong with my turbo and my new fender is on my car and painted now so good job again k thanks
and feel like paying for the lip? its 50 bucks how hard is 50 bucks
never mind from now on i will keep all my info to myself and let you go along like you are, i feel sorry for your car
Old Jun 12, 2011 | 05:20 PM
  #45
Old Jun 12, 2011 | 08:32 PM
  #46
tow truck on the way
Old Jun 14, 2011 | 09:16 PM
  #47
megaman311's Avatar
My guess is a crank position sensor. You have to use a scan tool to find out for sure. Not a cheap one, a good scan tool. When it happened to me, the code came up under the "pending codes" section of my scantool.
Old Jun 14, 2011 | 10:15 PM
  #48
ericgt79's Avatar
^^ you fucken NAILED it. i just talked to my well our GM Tech and he told thats exactly what it was.
Old Jun 15, 2011 | 02:14 AM
  #49
hehehhahwhhwhaahahhahamwwwuuuaahahahahhahahahahahh aa
you're good man.. a lil... 2 good... actually...
Old Jun 15, 2011 | 03:14 AM
  #50
megaman311's Avatar
I'm glad I can help. Being ASE certified helps
Remember, you can throw parts at it til it works, or you can diagnose the problem and fix it right the first time and save money.
