Car wont stay running
Old Feb 27, 2013 | 01:13 AM
LTBALTBMX's Avatar
Just bought a not running 06 SS/SC.
The previous owner claims that he was driving along when he heard a knocking sound. Car was turned off and towed home. At home, the car still started and it ran for a brief moment before dying on its own. Each time however, the car would run for a shorter duration than before, before dying.
Right now, the car is to the point where it will not even fire. It does crank but does not turnover.
What I have checked so far:
-Fuses all appear to be good. I pulled each one out and visually inspected them.
-The car is getting fuel. I undid the big 24mm nut on the fuel rail and pointed the line into a can. Fuel came gushing out at an appreciable rate (in my opinion). In addition, the cylinders stunk of fuel when I pulled the plugs out and the plugs were wet with fuel as well. Perhaps it was flooded?
-There are no codes being thrown according to my OBD scanner. I might have done this wrong though as I scanned it immediately after the battery was unplugged for 12 hours. I did not crank motor after connecting battery, only turned key to run.
-I popped off the valve cover. Everything looks good. Engine is very clean and I don't see any bent valves. Timing chain had a good amount of tension in it and it does not look like it slipped.
-Ran a compression test when it was outside in -10 deg. C weather. Cylinder was low at 140 PSI compared to the others at 165 - 180. Put car inside heated garage (20 deg. C), re-did compression test, and got between 170 - 180 across in all cylinders.
-I jacked up the car and removed the lower splash shield to access crank pulley. Tried turning engine with a ratchet by hand in a clockwise manner but it was extremely difficult, got maybe 5 degrees before i couldn't turn anymore. Sparkplugs were out during this time. Accessory belt was still in tension though, so that could be why.
-Throttle body looked good. Responded to the pedal.
-Sparkplugs look like this:
which corresponds to a condition called dry fouling.
-Had the cobalt connected to a corolla with its engine on. + on corolla battery to cobalt's remote + and - on corolla battery to strut tower nut. It sounded like this while cranking:
Not too sure, but compared to my LT, it sounded a bit weak.
-I tried roll starting it on an incline but that did not work. Popped clutch while car was in 2nd, didn't hear any intention to turn over from the motor.
-Cold air intake looks good from engine bay. Nothing loose. All the sensors appear to be tight too. Cant confirm that they are working though.
Any help offered is greatly appreciated. I will grab fresh sparkplugs today and check for spark.
Old Feb 27, 2013 | 01:16 AM
xxenjoi11's Avatar
Vacuum belt? Mass air flow sensor?
Daily driven? Sits alot? How weather? Snowy and cold? More info would help
Old Feb 27, 2013 | 01:20 AM
ujustgotshook713's Avatar
cold air come loose? throttle body/sensor? fuel pump fuse? these are a few things why this has happened to my car in the past. 06 ss/sc
Old Feb 27, 2013 | 03:20 AM
mahfouzman's Avatar
^^^It could very well be the fuel pump fuse. How many times have you turned it on? Does it get harder to crank over each time?
Old Feb 27, 2013 | 03:23 AM
cuebalt's Avatar
Check all the fuses, buddy of mine's did the same thing, turned out it was his exh fuse or something like that
Old Feb 27, 2013 | 06:03 AM
i just switch it out with the ac fuse everytime it messes up and it works fine after that. Hasnt happened in a while though. these cars are weird...
Old Feb 27, 2013 | 10:54 AM
mrbelvedere's Avatar
try posting in the problems and service section
Old Feb 27, 2013 | 11:00 AM
moved
Old Feb 28, 2013 | 02:21 AM
LTBALTBMX's Avatar
<snip>
Old Mar 2, 2013 | 11:49 AM
LTBALTBMX's Avatar
Updated original post with new details and organized info.
Turbo Johnny
Feb 21, 2019 09:41 AM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
Adam144
Sep 3, 2015 07:48 PM
