CEL after removing SC
Old Jun 25, 2008 | 05:59 PM
chris88z24's Avatar
I got bored today and pulled the blower off my car to plug the silencer holes. I ended up removing the blades from the housing and sanding down the inside to make sure it was perfectly flush and smooth with the sc housing. I refilled it with GM SC oil (almost 2 bottles worth) and installed everything back on the car. Now the CEL is on. Just wondering if anyone might know what caused it, or if unplugging the battery will reset it. Thanks.
Old Jun 25, 2008 | 06:00 PM
ItalianJoe1's Avatar
Did you reconnect all the vacuum lines and the sensor on top of the blower?
Old Jun 25, 2008 | 06:01 PM
chris88z24's Avatar
Yes. It runs and idles completely fine, but the idiot light is on. BAHHHHH I hate new cars so much... computers on wheels FTL.
Old Jun 25, 2008 | 06:04 PM
try the batt method of resetting it, or drive to autozone or someplace and find out what code it is.
Old Jun 25, 2008 | 06:17 PM
chris88z24's Avatar
Yeh, I am going to unplug the battery tonight and see if it does anything. I'd just leave it but my inspection is due at the end of June and I can't pass with the stupid ass retard light on.
Old Jun 25, 2008 | 09:36 PM
Coblasts's Avatar
It would be easier if we knew what code you are throwing.
Old Jun 25, 2008 | 09:37 PM
Perfect.disguise's Avatar
Much louder now?
Old Jun 25, 2008 | 10:18 PM
jeremie's Avatar
probably got a leak between the supercharger and intake. did you replace the gasket?
Old Jun 25, 2008 | 10:41 PM
chris88z24's Avatar
No, replacing the gasket is not necessary unless it is damaged.
The CEL went away. I drove it to work, let it sit for about 4 hours, then when I started it up the CEL was gone.
Weird.
Originally Posted by Perfect.disguise
Much louder now?
Hell yeah
Last edited by chris88z24; Jun 25, 2008 at 10:41 PM. Reason: Automerged Doublepost
Old Jun 25, 2008 | 10:50 PM
Weird.
Hell yeah
Did you turn the key on at all when you had something unplugged? That could set a temp code, that would clear after a few cycles.
Old Jun 25, 2008 | 10:52 PM
chris88z24's Avatar
Now that I think of it the key was in the ACC position the entire time.. lol
Old Jun 26, 2008 | 02:15 AM
Sharkey's Avatar
even if the light is off there will still be a code in history. go get it scanned, itll still be there.
turbochargedss2012
Sep 20, 2023 12:17 PM
DocSvensk
Sep 27, 2015 02:24 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
