CEL Codes
Old Jan 4, 2019 | 08:09 PM
Wind's Avatar
CEL Codes
So I have a P0420 and P0033.
I'm just going to chop the cat off but would the code for the P0420 disappear if I do? (from what I understand cat is probably not good based on previous posts)
Also would the P0420 cause the P0033 code to appear or do i need to change the Bypass Valve Solenoid?
06 2.0L Supercharged. Also from what I've read this is cause the car from making boost since according to the gauge no longer makes more than like 5 sometimes?
Old Feb 10, 2019 | 10:11 PM
Cleburne Red's Avatar
I'm no expert, but removing the cat is not gonna clear up a p0420, since that code is saying the cat isn't working in the first place.
Old Feb 11, 2019 | 08:45 PM
C0balts5's Avatar
3 options to fix the cat code
1. Replace with oem one or a really good aftermarket one
2. Install catless down pipe and install 02 sensor spacer in the downstream 02 sensor
3. Install catless down pipe and get a tune put on to delete the code.
as far as the supercharger code you may to take it to a performance shop to have it diag first or do some more research. I'm not too familiar with the supercharged cobalts.
Old Feb 11, 2019 | 08:58 PM
Wind's Avatar
It was more for if I remove it would it change to a different code altogether.
Thanks I’ll try the spacer thing then.
Old Feb 11, 2019 | 09:01 PM
C0balts5's Avatar
You can try a spacer first. Only think I don't like about with doing that is if your cat is starting to come apart and you put the spacer in, yeah the cat code will be gone but if it's bad enough it will break apart and clog up the exhaust.
Old Feb 11, 2019 | 09:02 PM
Wind's Avatar
yeah I meant to say I’m still cutting it off either way I’m turboing it soon just want to make sure these “small problems” aren’t something bigger
Old Feb 12, 2019 | 06:30 AM
C0balts5's Avatar
That'll be nice. I have a 08 lnf ss. Love the sound of the turbo.
kikal8
Jun 30, 2012 10:21 PM
Street>Track
Mar 30, 2011 10:50 PM
lindstromderek
Dec 11, 2008 07:53 PM
ikeryder13
Sep 30, 2008 04:15 PM
scotts2.0
Aug 28, 2007 10:19 AM
