CEL, REDUCE ENGINE POWER, CPS learn error
Old Jul 24, 2008 | 11:32 PM
chris88z24's Avatar
CEL, REDUCE ENGINE POWER, possible TPS error?
My car is gay. I Just installed stage 2 injectors, pulley, and a tune from xskier874 (thanks man) Ever since I put the 3" pulley on and have hit moderate boost (5psi at the max) the engine cuts out and goes into reduced power mode. We scanned for codes and got CPS learn error. Any ideas? I'm calling the dealer tomorrow. It's drivable, just does't go into boost.
UPDATE:
OK. Now the problem only occurs when I really floor it. It seems to happen in the upper RPM's (5000 and beyond). If I am cruising and hit boost it is fine. I reset it by unplugging both + and - terminals and touching them together, and by jiggling the connector around that sits under the TB. It clears the code, but it comes back and cuts power once the engine hits high RPMs (under boost)
HELP!! I'm in levittown, NY right now and have a 3 hour drive home. I don't want to limp the car back like I did on the way down. Argh..
Old Jul 24, 2008 | 11:44 PM
Cobaltss/TC's Avatar
Yup takes like a minute with the Tech 2
Old Jul 24, 2008 | 11:55 PM
chris88z24's Avatar
So what do they do just plug it in and relearn it? It won't erase my tune I have on there will it?
Old Jul 24, 2008 | 11:59 PM
Red2.4SS's Avatar
Nope wont erase it.
Old Jul 25, 2008 | 12:40 AM
chris88z24's Avatar
Originally Posted by Red2.4SS
Nope wont erase it.
Sweet. I'll have to get someone to relearn it tomorrow before my road trip. I drove 250 miles today with the car like this. Sucks so bad to drive a SS S/C in vacuum.
So do you guys think this will help fix it?
Well I let it sit for an hour. GO out and start it, no reduced power. BUT the CEL was on. I get to the end of my street and BAM reduced engine power kicks in
THIS SUCKS! I can feel the extra power from my pulley tune and injectors, then its all taken away from me. Worst feeling in the world.
Last edited by chris88z24; Jul 25, 2008 at 12:40 AM. Reason: Automerged Doublepost
Old Jul 25, 2008 | 12:41 AM
Usually does that computer needs to learn certain parameters from the cranks sensor and a few others.
Old Jul 25, 2008 | 12:43 AM
chris88z24's Avatar
Theres a saturn dealer right by my house, i'll run it there first thing in the morning and have them try to relarn it.
Old Jul 25, 2008 | 12:45 AM
Yeah like i said earlier it only takes a minute make sure the car is warmed up makes it a lot faster. What they have to do with the Tech2 is select the year then power train then engine type then special functions the CKP relearn rev your engine until it hits fuel cut-out then bam it is done.
chris88z24's Avatar
Yeah. I'll inform them of that just in case they are retarded. I hope it fixes it though.. it SUCKS so bad to drive in reduced power mode
Old Jul 25, 2008 | 12:47 AM
Yeah i would be pissed, damn computers
Old Jul 25, 2008 | 12:48 AM
chris88z24's Avatar
i was pissed.. try driving 250 miles with it like that. And having mustangs and ricer scion tc's rev at you and blow by you.
AHH!!!!!!
Old Jul 25, 2008 | 12:51 AM
AHH!!!!!!
Yeah i can understand. Well it should do the trick if not write back and maybe we can figure something else out.
Old Jul 25, 2008 | 12:53 AM
chris88z24's Avatar
ALright. The code was code 315 crank position not learned I believe. We tried clearing it in HP Tuners but it kept popping right back up.
Old Jul 25, 2008 | 12:55 AM
Yeah it will keep coming back tell it is learned.
chris88z24's Avatar
My buddy is going to do the relearn tomorrow at 1145. Hopefully that takes care of it and I can finally hit booooooost Thanks for your input/help btw man. Really appreciate it IMO this is how every thread on this forum should be. Helpful, friendly, and straight to the point.
Old Jul 25, 2008 | 12:57 AM
advise's Avatar
did you remove the pcm for tuning
Old Jul 25, 2008 | 01:05 AM
No prob glad to help
Old Jul 25, 2008 | 01:08 AM
chris88z24's Avatar
no. it did this before tuning as well. Don't know why. The key was left in the ACC position when I took the SC off so idk maybe a short or something. Or maybe the sensor is bad. Who knows. All started when I put my 3.0" pulley on.
Old Jul 25, 2008 | 01:35 PM
chris88z24's Avatar
WTF. Got the crankshaft relearned, ran great. I was testing out some WOT, ran fine. I hit 7k and shifted to 3rd and BAM,.. reduced engine power again! WTF!
The Tech 2 was saying throttle position sensor.. i think the code was p0122. but would that make the car go into limp mode?
Help! THis is so gay I have a 3 hour drive to long island soon
Old Jul 25, 2008 | 01:43 PM
06blackg85ss's Avatar
I've been reading that it might need a CPS-relearn which can easily be done with a tech II scanner.. what do you guys think?
Too bad you didn't hold out til I was free
I'll be back tomorrow night from Jersey if you're still around, just not til really late, I'll be in Warwick NY on sunday tuning another turbo converted cobalt.
Last edited by 06blackg85ss; Jul 25, 2008 at 01:43 PM. Reason: Automerged Doublepost
Old Jul 25, 2008 | 02:12 PM
chris88z24's Avatar
Alright. Can you PM me your cell? I'll be in levittown, LI so if the car is still acting up I will give you a call. I cleaned the TB and reset the computer to clear the codes.. took it out for a hammer and it was ok. But I didn't really beat on it. So we'll see.
Old Jul 25, 2008 | 02:40 PM
9178079309
Old Jul 26, 2008 | 01:24 AM
chris88z24's Avatar
OK. Now the problem only occurs when I really floor it. It seems to happen in the upper RPM's (5000 and beyond). If I am cruising and hit boost it is fine. I reset it by unplugging both + and - terminals and touching them together. It clears the code, but it comes back and cuts power once the engine hits high RPMs (under boost)
Old Jul 26, 2008 | 12:41 PM
chris88z24's Avatar
bumpp.. anyone have an idea as to what is going on?
Old Jul 28, 2008 | 03:04 AM
chris88z24's Avatar
edited the 1st post...
Last edited by chris88z24; Jul 28, 2008 at 03:04 AM. Reason: Automerged Doublepost
