Charging Problem!! :( Please Help
Old Apr 4, 2012 | 08:34 PM
John Cherney's Avatar
So... i have a 2005 Cobalt SS 2.0L LSJ turbo SWAPPED..and i have been without the car for about a month now.. For some unknown reason, my car wont charge my battery. I hopped in the car and drove down the street and the battery light comes on and chimes, after driving for about 20 mins to a half hour on a full charge, the electric starts to dim and the car shuts off. The fuel pump is the last thing to shut off.. I just changed the alternator twice and battery twice, checked all grounds and wiring. I even disconnected the new lights i just installed because i thought that may be the cause. Any ideas what it could possibly be? I ran the computer and it says there are no codes.. im currently searching a wiring diagram for the computer to see if the wire from the computer to the alternator is making a connection or not... I checked the connector connecting to the alternator (possible voltage regulator) and it does not light up car running or not.. PLEASE help me get my car back ANY IDEAS???
i want my car back!
Last edited by John Cherney; Apr 4, 2012 at 08:34 PM. Reason: Automerged Doublepost
Old Apr 4, 2012 | 09:05 PM
jthomas9's Avatar
Old Apr 4, 2012 | 09:12 PM
07darknight's Avatar
There is a fusable link that goes from the alt to the starter I would start by checking all ur maxi fuses and if they look good that Is most likely ur problem
Old Apr 4, 2012 | 11:50 PM
mrbelvedere's Avatar
or a bad excite wire going to the regulator in the alt
Old Apr 5, 2012 | 09:32 AM
tomj77's Avatar
I would say ur belt tore off but since u changed the altimator, that's out, unless u forgot to put it back on. Do u have anything connected to the batt? Like amp or hids, if so disconnect them and see what happens, could be parasitic drain from something u added.
Old Apr 5, 2012 | 09:33 AM
tomj77's Avatar
Did u upgrade ur altinator when u turboed?
Old Dec 6, 2012 | 04:25 PM
kronic420haze's Avatar
did this ever get.solved. im having the same issue
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
