charging system problem
Old Dec 24, 2012 | 12:48 PM
kronic420haze's Avatar
ive been have charging system issues and need help. i replaced the alt with a.good used one. its been tested. i bought a new stage 1 ecu from zzp and i had sears check the battery and said it checked out ok. my charging system light comes on when i drive the car. itll go on and off at first then after about 45 min to a hour itll shut down my abs then power steering then lights go and itll die out. i had a mechanic and the local alternator rebuild guy check it out and the.cant figure it out. but both think possibly the pcm. but i think o changed that if its the same as the ecu. anyoje have similar problems or have any ideas
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
