check engine light
Old Mar 16, 2010 | 05:02 PM
Mike08ss/tc's Avatar
check engine light
I have been getting a eng power reduced light keep coming on. It would go back off after i reset it and everything. I thought it was just my intake messing up my tune in the cold weather. But it is now very nice out and there should be no reason for that. These were the codes that they gave me at autozone.
p2096
p0091
p0302- cyclinder #2 misfire
p013e- fuel metering system
My eng power reduced light will sometimes come on when i back up.
MODS:
Hahn cai
Hahn 3' catback
zzp 3' catted dp
dejon charge piping
Thanks
Mike
Old Mar 18, 2010 | 12:39 PM
car will not really even run now.
Old Mar 18, 2010 | 01:32 PM
insylem's Avatar
#2 Fuel Injector toasted?
Check the plug first and coil pack since they are eayser.
But I could see #2 injector causeing your #2 misfire,
and that its part of the fuel metering system could throw
the other code(s) too maybe?
Old Mar 18, 2010 | 06:02 PM
when you say check the coil pack, how would i go about checking that on these cars. these cars are so sensitive i dont want to mess anything uo worse.
Thank you
Old Mar 19, 2010 | 11:00 AM
insylem's Avatar
Thank you
Swap coil pack from #2 to #3 position.
Run car, see if code P0302 changes to P0303.
If code changes, then the coil pack is bad. If
code stays P0302 then coil pack is good.
Old Mar 19, 2010 | 11:24 AM
ok thanks.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
