check engine light?
Old Sep 25, 2007 | 05:17 PM
ssaddiction's Avatar
check engine light?
ok so i got a stage 2 installed today and left the dealer and went home and put a step colder plugs in now i notice that my check engine light is on is this normal and will just go away by itself or should i get it checked out? please help
Old Sep 25, 2007 | 05:19 PM
light'bolt's Avatar
Take it back, and check your gas cap.
D4u2s0t's Avatar
without the code no one can tell you what it is. no one can speculate. it could be 2 billion different things. since you had it done at the dealer, take it back and tell them to fix it.
/thread
Old Sep 25, 2007 | 05:37 PM
and now i notice when its idleing that there is a loud noise like air sucking threw something that i havent heard before?
Old Sep 25, 2007 | 05:38 PM
XM15's Avatar
^^^Bring it to the dealer as soon as you can.
Old Sep 25, 2007 | 05:52 PM
Coblasts's Avatar
Are your plugs tight enough !!!!
If you can hear the noise listen and track it down .
Old Sep 25, 2007 | 06:13 PM
it sounds like the noise is coming from the injectors or right around them anyone know what it could be its def air sucking in somewhere?
Old Sep 25, 2007 | 11:00 PM
rukkee's Avatar
If they screwed up the grommet that sits in the head it will cause it to leak. It's also possible that they installed the injectors without lubing the o-ring's causing them to roll and not seal correctly.
If you hear a noise it could be quite a few things including ..... supercharger to intake tube couplings ... supercharger manifold gasket... various vacuum lines. Do you smell fuel at all? Good luck
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
