Check engine light after the fan mod!
Damn... I was beginning the fan mod today. Because I didnt have all the necessary wires, I just used the "FAN1" part of the job. What I mean is that I simply removed the "FAN1" relay so I could jump it with a switch. When the swtich was on, both of the fans runed at 50%. When the switch was off, no fan turned on. That's ok, until I started the car. Only ONE fan went at 100%, the other one didnt function at all. Plus, few minutes later, I got a CEL. So even if the swtich was off, the fan continued to be at 100%. When it was on, BOTH fans went at 100%.
The fan which runs, when the switch is turned off, only stop when the car is stopped after like 10-15 seconds. This isn't cool, and I tried anything safe (unpluging one of the 3 relays which control the fans, or all of them or two of them, etc) and the problem remains.
****! What to do now?? It seems like the computer is all mixt-minded...
you have the wires jumped wrong, you need to put the relay in with the set up
i.e. have relay but on the correct wires put a switch, so the fans function as intended but can stay on 100% when needed
i dont suggest this mod, get tuned for lower fan temps...if not an option then you dont have the mods necessary to hack your wiring
TurboTechRacing
Oct 27, 2015 07:58 AM
