check engine light on from cai
Old Mar 14, 2008 | 12:52 AM
valentino0214's Avatar
Angry check engine light on from cai
check engine light (MIL) came on after installing my cai it breaks up sometimes at random rpms and i have to shift.. PLEASE HELP if anyone knows wat wrong got robbed from the dealership and its under warrenty
Old Mar 14, 2008 | 01:05 AM
JBomm's Avatar
Is the filter oiled? If it is that is most likely your problem. Your car is throwing the MAF code. Get a non-oiled filter and get the ecu cleared.
Old Mar 15, 2008 | 11:01 AM
rukkee's Avatar
I doubt its an oiled filter issue seeing as most people here run K&N and injen CAI's without issue. I would look for a leak or loose clamp . Is it possible that the maf is installed upside down or not tight? I ran a K&N drop in / airbox mod for over a year without issue , it would have to be way over oiled to cause a problem. How much vacuum are you pulling on the gage at idle?
Old Mar 15, 2008 | 11:03 AM
stage2's Avatar
what intake is this?
Old Mar 15, 2008 | 11:06 AM
SSRedSC's Avatar
did you reset your computer by unhooking the battery for a little while so that it can recalibrate the air fuel ratio
Old Mar 15, 2008 | 11:07 AM
BigTizzle903's Avatar
sounds like a loose connection somewhere. i'd go check all your clamps and the maf.
Old Mar 16, 2008 | 02:55 PM
im not sure i think a titan cold air... i put oil on the filter and i think im gonna clean the filter off thanks guys
brandon04
Oct 21, 2015 07:04 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
