Check engine light :( misfire, lean, MAF
Old Sep 27, 2013 | 07:20 PM
Dexter's Avatar
I saw there was a few posts similar to my issue but not the exact same, I have a 2007 supercharged cobalt and i put a takeda cold air intake on it, 2 days later a check engine light came on and now it is running horribly. the car has a really bad misfire, slight trouble starting, bog and ofcourse the C.E.L. I have 3 codes, one says its running lean, one says i have a random misfire, the third says its a mas air flow sensor. I cant remember the codes for sure but i believe they were 101, and 114 but im not 100% on that. if anyone has had these can you help me out
i was told that putting a new map sensor and mass air flow sensor will fix it but if its caused by my Cold air wouldnt it just come back?
i cleared the codes with a reader and it did help the misfire but it came back along with the check engine light.
Thanks guys!
Old Sep 27, 2013 | 07:34 PM
Not trying to be a dick, but its your intake messing everything up, put the stock back on
Old Sep 28, 2013 | 09:32 PM
Dexter's Avatar
Any other advice?
Thx
Old Sep 28, 2013 | 09:44 PM
YelloEye's Avatar
The SS/SC shouldn't have issues with the intake. You MAF might need replaced or cleaned though.
Old Oct 1, 2013 | 10:47 AM
mrbelvedere's Avatar
the ss/sc will have problems with an intake change it needs to be retuned or stock intake put back on
Old Oct 1, 2013 | 08:25 PM
YelloEye's Avatar
First I've heard of that. I know the SS/TC is super picky, but I hadn't heard that about the LSJ.
Old Oct 1, 2013 | 08:35 PM
nhanson's Avatar
Depends on the intake for the LSJ...but they do mess with the car.
Adiaz1ss
Sep 26, 2015 11:51 PM
dieGone
Sep 23, 2015 10:20 AM
jthwjde
Sep 7, 2015 09:24 AM
Fearedbynone
Sep 4, 2015 10:24 AM
