Cigarette Outlet Not Working
Old Sep 28, 2007 | 09:11 AM
biniecki's Avatar
Here is the story. The other day I plugged my cell phone charger into the outlet located under the climate control. When I removed the charger, for whatever it fell apart. I noticed that there were some parts in the outlet that I could not get out with my fat fingers. My fiance was with me and she tried as well without success. Without thinking clearly she stuck a key into the socket trying to use it to retrieve the part. This resulted in a spark and the outlet no longer works. I have checked the fuses panels but did not see anything marked for the outlet. The other outlet by the ebrake works fine and nothing else seems to be not working. Any ideas as to where the problem may lye. I think its a fuse but I just don't know which one. Or the wiring may have fried.
Old Sep 28, 2007 | 10:30 AM
ssaddiction's Avatar
we have 2 diffrent fuseboxes one is under the hood and one is on the passenger side...you have to remove the pannel under the glove box on the left youll need a flashlight
Old Sep 28, 2007 | 10:43 AM
an0malous's Avatar
the cigarette lighter fuse is in the fusebox under the hood.
Old Sep 28, 2007 | 11:56 AM
biniecki's Avatar
Do you know what it is marked as?
Old Apr 5, 2011 | 11:23 AM
thejobman's Avatar
bump - i am having the same issue!
Old Apr 9, 2011 | 06:57 PM
never2fast's Avatar
i just replaced that the other day i believe it says a/c outlet its under the hood.
Old Apr 9, 2011 | 07:16 PM
mongorat427's Avatar
Yep under the hood.
Old Apr 9, 2011 | 07:33 PM
DiabeticKripple's Avatar
just check all your fuses. i did mine and found a fried one apparently my tail lights weren't lighting up at night
Old Apr 9, 2011 | 07:56 PM
C_A_D88's Avatar
I know ones a 20 and ones a 15, pretty sure the one your looking for is the 15 it's on the left hand side of the fuse box under the hood
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
jmelton327
Sep 26, 2015 10:04 PM
