Clicking noise im probably just paranoid
Old Jul 23, 2006 | 05:17 PM
jester's Avatar
Whenever i let the clutch out to start I hear a clicking noise. And today it did two clicks in a row. Im not sure if this is a problem or not. The clutch feels fine im just wondering if anyone else has had any experience with this issue.
Old Jul 23, 2006 | 05:18 PM
Kemo's Avatar
go to the car, press the clutch in and out, see if it makes that click sound... i know mine does. just a switch as far as i know.
Old Jul 23, 2006 | 05:20 PM
jester's Avatar
No it doesnt do it unless im trying to move. Its just gotten progressively louder
Old Jul 23, 2006 | 05:34 PM
Gory's Avatar
mine dose it as well i thinks it might be broken springs in the clutch hub.
Also mine is kind of jerky in 1st/2nd.
Old Jul 23, 2006 | 05:37 PM
Kemo's Avatar
ah, i thought you may have been referring to the click you here when you engage and release the clutch... my bad.
97 Z Me Go's Avatar
Someone correct me if im wrong but i belive its the LSD. My firend had a 6 speed 350z and it made the SAME noise except it came from the rear on the 350z on on ours it comes from the front. So it makes me belive its the LSD unit.
Do you have the g85?
If not then Im wrong but I get that noise also on mine and yes i have the G85
Kyle
StinkBOMB's Avatar
You sure it's not that little plastic switch down there? Peek under your steering wheel and check it out. Mine clicks if I push the clutch in all the way. If it ain't that switch, yell at the dealership.
Old Jul 23, 2006 | 05:41 PM
stotte20's Avatar
i hear the noise all the time mine comes from the back passgenger side it does it as im leaving off the clutch.
Old Jul 23, 2006 | 06:47 PM
jester's Avatar
No I dont have the G85 But I also have a pretty jerky 2nd gear shift no matter what I do I mean im only 20 but iv been driving standards forever, I learned on a 1970 with the 3 on the tree silverado with a straight six, but anyways it still seems a lil rough, i have 5650 miles on it and its about 2 and a half months old.
Old Jul 24, 2006 | 01:35 PM
Above6k's Avatar
Same problem here..I have a 06 ss/sc G85 and whenever I blip the throttle and let out anything but SUPER easy I get that click too. It's really noticable when parking and moving out in reverse, but I can actually slightly hear it when driving if I feather a shift from like 4-5.5K. It's at the dealership as we speak. I'll let you know what i find out.
Old Jul 25, 2006 | 03:56 PM
cragi9's Avatar
In the last couple weeks I have also been hearing this click noise as I shift. I have an '06 SS/SC w/g85. Car seems to be running perfectly fine though, but curious to see if anyone figures this out.
Old Jul 25, 2006 | 04:33 PM
cawpin's Avatar
Just so you know, you didn't learn on a 1970 Silverado.
Old Jul 25, 2006 | 06:29 PM
joeworkstoohard's Avatar
mine makes a slight tapping when the clutch is out (in gear) with the clutch released, it is super quiet. i plan to take it in for this.... i don't expect it to be anything major
Old Jul 26, 2006 | 12:40 PM
Above6k's Avatar
Just got the car back...They said it was the axle nuts. They re-torqued them and no more annoying "click"!
Old Jul 29, 2006 | 09:08 AM
Sunny's Avatar
Thanks Above6k. I am getting the same clicking noise. Now I know what to tell the dealer. Maybe this time they will listen to a woman.
Old Jul 29, 2006 | 02:06 PM
socalsilverRL's Avatar
I own a 2005 Redline and I have the same problems. I only notice the problems when I am starting in first gear, and second gear, or downshifting. I am going in for service on Tuesday to see what te problem may be. I also notice after a while that the trans. will make a , singular, LOUD pop when the car starts to get hot.
Old Aug 4, 2006 | 03:23 PM
just following up:
Got the verdict back from the dealer. Broken axle due to loose intermediate bearing.
Old Aug 4, 2006 | 04:05 PM
Shortbus's Avatar
I dont have g85, my car does the same thing, when going from a stop, and releasing the clutch and starting to move it does it.
Old Aug 4, 2006 | 06:17 PM
EtyrnuSS's Avatar
Had the same kind of noise on mine, was bad axles.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
