clutch problem on normal driving (recall?)
Old Dec 22, 2005 | 01:10 PM
vip37's Avatar
just wondering if anyone knew of clutch problems on the 2005 regular cobalt...my clutch pedal sunk to the floor at 2536 miles...Im waiting at home now with only a day and a half gone by for a tow truck to ramble on over.....any recalls on this? dont appear to be the clutch itself, more a problem with the clutch pedal/cable assembly...I didnt ask much when i brought it in first time, but you bet ur ass i will now....
mind you, this is normal driving, first time it happened as i was going to back it out of a parking space, next when I was pulling off a highway, so not like im beatin on it...
checking lemon laws now
thanks
Old Dec 24, 2005 | 07:48 AM
denniss's Avatar
Just checked, no recalls or bulletins for your problem.
Dennis
Old Dec 24, 2005 | 09:20 AM
Adirondack_Cobalt's Avatar
aren't the clutches on the base Cobalts hydraulic? I could go outside and check, but it's snowing...
Scott
Old Dec 24, 2005 | 10:12 AM
codyss's Avatar
Aren't they all hydraulic?
The 1998-2000 F-Bodies had this problem. A small screen was used in the fluid line to soften clutch engagement to save the weak rear end. The unwanted effect of this was the fluid would foam up and the clutch pedal would stay down until you pulled it back up.
So with all of that said it seems as if there is air in the system.
Old Dec 24, 2005 | 05:01 PM
Erod's Avatar
Moderator Alumni
Moved to problems and service forum
Old Dec 24, 2005 | 05:27 PM
Cirrus's Avatar
thanks
Your car is far from being considered a lemon if this is the only problem... Though, you might want to drop in call by GM (not the dealer) about the same problem not being fixed after 3 times.
Old Dec 26, 2005 | 03:26 PM
wesmanw02's Avatar
Interesting, I've never heard of that before.
Does it affect the 2001-2002 models as well, or just the 1998-2000 F-bodies??
Old Dec 28, 2005 | 12:46 AM
codyss's Avatar
In 2001 they went with a different set of hydrualics and a Z06 Clutch assembly.
Old Dec 28, 2005 | 12:16 PM
vip37's Avatar
Question
well, got the car back and they didnt replace anything...just said that there is a ball and socket connection on the cable and chevy said just to press it back together...dealer said he thought this will probably re-occur and looks like an upcoming recall....so guess i need to keep a big stopping distance...very odd situation to be in. time will tell im sure.
thanks for the replies.
vinnie
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
