clutch problem really weird.
Old Feb 16, 2009 | 03:23 PM
eurochevy's Avatar
Arrow clutch problem really weird.
ok guys so weird thing here...say i floor it..doesn't matter what gear because i was thinking maybe it only does it in a certain gear..no does it for all.. the clutch pedal with disengage/engage at the top to start off..and then if i floor it and go to shift into the next gear (like you would for example if ur racing at the track)..there will be absolutely nothing but air at the top of the clutch pedal and it will disengage / engage and only be feel in the last like maybe 20% of pedal travel..like i said only after i floor it doesn't matter what gear...i changed the brake fluid when i did my brakes with dot-4 instead of dot-3 but shouldn't make THAT much of a diff specialy since how it only started doing this for 2 weeks or so or that i've noticed ..any ideas ppl?
Old Feb 16, 2009 | 03:25 PM
Cobalt Mav's Avatar
Well, you're supposed to use dot-3, and maybe your clutch is gone?
Old Feb 16, 2009 | 03:33 PM
eurochevy's Avatar
clutch is decently gone to the point where i can't put too much power down in 1st gear yes but that doesn't explain why only when i floor it does it do it
Old Feb 16, 2009 | 07:29 PM
Nighthawk243's Avatar
Did you properly bleed the system when you did the brakes?
Old Feb 16, 2009 | 07:31 PM
Nussle's Avatar
same exact thing happens with mine. i dont know the answer, it just randomly started doing it one day.
Old Feb 16, 2009 | 07:32 PM
Black SS/SC 06's Avatar
I think this is common. My clutch is kind of weird sometimes and it does something that is different from the other cars I have owned. It almost feels like a pressure build up or something in the pedal. Im not really sure. All of my vehicles have been manuals.
Old Feb 16, 2009 | 09:50 PM
Sharkey's Avatar
my clutch will do something similar. if i drive off in 1st easy then stomp it from a roll, on the 1-2 shift the clutch pedal will be quite hard, and when i let the pedal back out it will only have pressure about 1/2 way up, and when i shift for 3rd the pedal will be half way down, but quite firm. after stepping on the clutch a few times it will feel normal again.
as far as i can figure, its something to do with the self adjusting pressure plate. i think when you push the clutch in at the higher rpm of a stage 2 kit the centrifical force causes it to move to the "max worn out" point, and after pumping it it will adjust itself back to normal. what i havent been able to get is an answer from someone who had this happening and put in a non SAC style clutch (exedy hyper single, andy on SAC spec, ect) as to weather or not they still had this happening or if it cleared it up.
Old Feb 17, 2009 | 04:00 AM
eurochevy's Avatar
ok thx guys at least i know im not the only one...its just a really pissing thing to happen its freaken hard to tell where the shift point is sometimes after..and yea like you said pumping it after once or twice usually fixes it pretty quick or if u just wait a bit
Old Feb 17, 2009 | 11:20 AM
SSdan's Avatar
Mine does the same **** too. Only when I'm spraying at the top of 3rd into 4th. Completely lose half the pedal until I pump it 5 times.
Old May 3, 2009 | 02:51 AM
damien's Avatar
Anyone figure this out? I'm thinking dirty fluid / air in line.
Old May 3, 2009 | 03:07 PM
Nussle's Avatar
yeah i really wanna know. im planning on getting a new clutch soon and would like to get this fixed.
Old May 3, 2009 | 05:39 PM
gos2difbeat's Avatar
bleed the clutch again. i had the same problem and me and a buddy bleed the clutch and after that the problem was gone.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
