Clutch problems need help
Old Feb 9, 2012 | 02:45 PM
timhebert's Avatar
Changed clutch about 6 months ago now my clutch won't disengage. Slowly started to lose fluid kept refilling but could never find leak. Looks like fluid on the bottom of bell housing . Is it my slave cylinder or TOB
Old Feb 9, 2012 | 05:04 PM
FasterIsBetter's Avatar
Basically your tob is made into your slave cylinder. I'd check the seal on your clutch pipe before you pull the trans.
Old Feb 9, 2012 | 05:12 PM
Also the seals on your master cylinder output fitting. But its most likely your slave.
Old Feb 9, 2012 | 06:37 PM
timhebert's Avatar
I changed TOB when I did clutch what's the chances of it going out this fast? Would the pipe leaking cause it not to disengage, wherever it is it's a slow leak, I bleed lines to get air out but still won't disengage and the petal is stiff like new
Old Feb 10, 2012 | 01:33 PM
timhebert's Avatar
Is there anyway to test pipe for leaks
Old Feb 10, 2012 | 01:36 PM
Yeah, if it was a seal it could still be a slow leak. And yes, if you have debris in the lines or air in them you can blow out your seal in your tob.
Old Feb 10, 2012 | 06:34 PM
timhebert's Avatar
If I blew out seal in TOB it wouldn't hold pressure and I'd lose all fluid right?
Old Feb 10, 2012 | 06:36 PM
TurboTechRacing's Avatar
It will slowly leak out, could take a few weeks, also you will get oil on the clutch disc, so that will be garbage too.
Old Feb 10, 2012 | 06:57 PM
timhebert's Avatar
Wtf does crate engine depot warranty there TOB. Cause it's only 9 mths old?
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
