Clutch/Shifting issues
Old Feb 23, 2012 | 07:07 PM
iTwitch's Avatar
5th gear in my LNF (2008) likes to pop out. I have a Twm sts, charge pipes, trifecta tune. 23psi. Not that that information is too useful, it only started doing this when the clutch started to get worse. Anyone have the issue or know anything about it? Thanks fellas!
Old Feb 26, 2012 | 02:01 PM
iTwitch's Avatar
Nothing? Damn
Old Feb 26, 2012 | 02:21 PM
Powell Race Parts's Avatar
verify that the shifter is adjusted properly. put the car in fourth gear, loosen clamps, let the cables run free to find the correct position, while u re locate the shifter rod in the 4th gear position pushing the shaft slot into 4th gear locator, lock up tabs and check how it works.
probably need a transmission sucks to suggest that...
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
