Cobalt won't start, Video
Old Oct 23, 2013 | 01:55 PM
CCBalla10's Avatar
Hey guys woke up this morning to 35 degree weather when heading to work and found out my car won't start. Anyone have any ideas? Linked is the video of the sounds/process
Old Oct 23, 2013 | 02:03 PM
CoBOLTingSS's Avatar
It sounds like mine when I had to replace the crank position sensor....
2006 Chevrolet Cobalt Parts - GM Parts Online - GM Parts Direct
Old Oct 23, 2013 | 02:19 PM
CCBalla10's Avatar
is there some kind of test I can do to see if it is bad?
Old Oct 24, 2013 | 02:28 PM
CCBalla10's Avatar
ok got the car running after sanding some of the rust off the ground under driver side headlight. Starts right up, but now I have a new issue which im hoping is an easy fix. As soon as i turn the key, the fans behind the radiator/front of engine ramp up high and my coolant temp when i start it says ---
Old Oct 24, 2013 | 02:40 PM
andrewcarr1993's Avatar
Seems like a bad thermostat.
Old Oct 24, 2013 | 02:42 PM
ThexGovenor's Avatar
can you get the code?
Old Oct 24, 2013 | 02:46 PM
CCBalla10's Avatar
I'm on my way to the auto parts store to pick up a few new relays for the fuse box under the hood. I'll swap out some of those that i think may be bad and report back.
BTW I did some relay swamping in that box to make sure my crank relays were good. Could be i swapped a bad relay in the cool/fan spot
Old Oct 24, 2013 | 04:39 PM
CCBalla10's Avatar
Bought all new relays for the crank/run spot in the engine fuse box and she's running like a champ! Glad this was such an easy fix, even though it was time consuming. Total fix cost was roughly $58
Wind
Sep 11, 2015 06:57 PM
Bluelightning
Sep 8, 2015 05:18 PM
Sabon_SS
Sep 7, 2015 12:39 PM
